Wacom Intuos Art Black PT M South
Quicklinx: BVGFWS00 Mfr#: CTH-690AK-S
Unleash your creativity with the Intuos. It includes Wacom’s leading pen & touch tablet technology. So whether your dream is starting your portfolio, racking up some ‘likes’, or pushing the limits of creativity, Intuos has everything you need to make it happen.
  • You're closer than you think
    Whatever your creative style - or level of skill - Intuos can help you reach the next level. With four different versions, there's one to match you and your creative work exactly. And because you already know how to draw with a pen and paper, working with the Intuos pen is simple and natural. As you explore the possibilities, your work will develop in new directions from your very first creation.
  • Create something amazing
    Whatever your artistic ambitions, an Intuos can take you there. Beautifully designed and super-simple to use, each pen tablet comes with a free creative pack that includes downloadable software, services and online tutorials too.
  • Creativity with no limits
    Take your skills to the next level. With an Intuos pen in your hand, you can easily switch between pastels, pencils and photo editing tools. Controlling your tablet couldn't be easier either. With touch technology, you can use the same gestures you would on your smartphone to pan, zoom, and navigate your canvas.
  • Creative software to get you going
    Whatever you're into - drawing, painting, photography or comics - each Intuos pen tablet comes with creative software made for what you want to do. Just plug in your tablet, register and download to get started.
  • Made for a quick start
    Getting started couldn't be simpler. Just plug a single USB into your Mac or PC. Install the software driver and you are ready to start. With the help of online tutorials, you'll be creating in no time.
  • Sleek and chic
    The fresh design is super slim, ultra-light, comfortable to use and portable.
Wacom Intuos Art Medium - digitiser - USB - black
Digitiser
Wired - USB
Orientation
Right and left-handed
27.5 cm x 21.7 cm x 1.1 cm
480 g
Multi-Touch
Movement Detection Technology
Electromagnetic
Buttons Qty
4
Movement Resolution
2540 lpi
Performance
133 points per second
Eraser, multi-gesture touch pad, multi-touch digitiser, ExpressKeys
Apple OS X 10.8.5 Mountain Lion or later, Microsoft Windows 7 / 8 / 10
Digitiser
Orientation
27.5 cm
21.7 cm
1.1 cm
480 g
Input Device
Wired
USB
Electromagnetic
Multi-Touch
Buttons Qty
4
Movement Resolution
2540 lpi
Performance
Pressure Levels
1024
Active Area
21.6 cm x 13.5 cm
1 x USB - 4 pin USB Type A
Stylus holder, replacement pen tips, colour identification rings, stylus pen, USB cable
Software Included
Drivers & Utilities
