Team up with the Cintiq Companion 2 to enjoy total creative freedom. The superior natural pen-on-screen drawing experience brings each remarkable detail of your expression to life with exquisite accuracy. Plug into your Mac or PC, or go find a favorite spot - either way, the Cintiq Companion 2 can run intensive creative software, and stands ready to inspire demanding artists and designers.
Designed to fit your imagination
The Cintiq Companion professional creative tablet is an incredible partner for demanding creative professionals. When the pen meets the screen, you can count on performance that delivers the pure, natural expression your creativity demands. -
Pro Pen: serious artistry with a natural feel
This fluid pen-on-screen experience feels as natural as pen-to-paper. Pressure levels precisely capture details, and a range of nibs give you the exact feel you like. Tilt the pen for comfortable drawing angles. The result: every stroke, every line, rendered with finesse. -
Creative tablet: engineered for inspiration
Feel the friction of a natural pen-on-paper experience on the wide angle display, with a specially micro-finished glass touchscreen that reduces glare. With excellent screen resolution and an impressive range of colors, watch your ideas come to life instantly. -
Your compact, full-service studio
The Cintiq Companion features a powerful processor that runs creative and business software. You have the power to host a call, give a presentation, access your email, stream movies, or listen to music and switch easily back to creative mode with the applications you need. -
Just plain friendly
Creativity needs flexibility. This incredible professional creative tablet features Cintiq Connect technology that adapts easily to the work experience you want, where you need it.
- Wacom Cintiq Companion 2 - 13.3" - Intel Core i7 - 4558U - 8 GB RAM - 256 GB SSD
- Product Type
- Tablet
- Operating System
- Win 8.1 Pro
- Processor
- Intel Core i7 (4th Gen) - 4558U / 2.8 GHz, up to 3.3 GHz / 4 MB Cache
- Memory
- 8 GB DDR3
- Storage
- 256 GB SSD
- Display
- 13.3" touchscreen 2560 x 1440 / WQHD
- Graphics
- Intel HD Graphics 5100
- Input Device
- Touch-screen
- Integrated Webcam
- Networking
- 802.11b/g/n, Bluetooth 4.0
- Battery
- Up to 4.5 hours
- 37.4 cm x 24.8 cm x 1.5 cm
- 1.7 kg
- Limited warranty - parts and labour - 1 year
- Product Type
- Tablet
- Operating System
- Windows 8.1 Pro
Processor / Chipset
- CPU
- Intel Core i7 (4th Gen) 4558U / 2.8 GHz
- Max Turbo Speed
- 3.3 GHz
- Number of Cores
- Dual-Core
- Cache
- 4 MB
- 64-bit Computing
- Intel Turbo Boost Technology 2.0
- RAM
- 8 GB
- Technology
- DDR3 SDRAM
Storage
- Main Storage
- 256 GB SSD
Display
- 13.3" - IPS
- Touchscreen
- Yes (multi-touch)
- Resolution
- 2560 x 1440 (WQHD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72% NTSC
- 72% NTSC colour gamut
Audio & Video
- Graphics Processor
- Camera
- Resolution
- 8 Megapixel (rear), 2 Megapixel (front)
- Sound
- Stereo speakers, two microphones
Input
- Touch-screen
- Pressure sensitive pen, right and left-handed, ExpressKeys, Rocker Ring
Communications
- Wireless
- Technology
- Lithium polymer
- Run Time
- Up to 4.5 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 48 Watt, 19 V, 4.74 A
Connections & Expansion
- 3 x USB 3.0 , Mini DisplayPort , Headphone output
- Memory Card Reader
- Yes (SDHC Card, microSD)
- Security lock slot (cable lock sold separately), volume control
- Included Accessories
- Power adapter, carrying case, pen case, 9 replacement nibs, nib removal tool, Pro Pen, stand
- Cables Included
- Data cable
- C-Tick, BSMI, CB, FCC Part 15 B, CCC, FCC Part 15 C, RoHS, KCC, GOST-R, VCCI Class B, China RoHS
- 1.7 kg
