Enjoy creating directly on a large-format, high-definition display with Wacom's pressure-sensitive pen. This industry-leading pen display was designed to meet the needs of creative professionals. With ample screen size, advanced display performance, and intuitive productivity tools, no wonder Cintiq 22HD is such a popular choice.
Professional precision.
Wacom's premium, pressure-sensitive pen provides natural, on-screen creative control and captures every nuance of your movements with the accuracy and precision of traditional art tools.
Create in comfort.
The traditional rotating stand offers both landscape and portrait viewing angles and easily adjusts to your preferred working position, so you can work in complete comfort.
Maximize your productivity.
16 customizable ExpressKeys™ provide easy access to your shortcuts on this creative pen display. Rear-mounted Touch Strips let you pan, zoom, rotate, navigate, and more with a tap of your finger.
Insights for animation & game
In the 2D world of concept art, character development, story boarding, matte painting, and other disciplines, creatives are making huge productivity gains by working on Cintiq creative pen displays. Independent studios and marquis production houses alike are pairing Wacom displays with advanced software for greater results.
3D Sculpting
To produce life-like results quickly, professionals depend on a streamlined workflow. With your favorite software, you can mold, shape, sculpt, and animate your character mesh, all with the intuitive and natural precision of a Cintiq creative pen display.
Video editing & motion graphics
The process of editing video can be time-consuming. Wacom Intuos Pro creative pen tablets and Cintiq creative pen displays provide a more intuitive and comfortable way to work with your favorite applications, helping you create stunning work in less time.
- Wacom Cintiq 22HD - digitiser - USB
- Digitiser
- Connectivity Technology
- Wired - USB
- Display
- LCD display - 21.5" - 1920 x 1080
- 65 cm x 40 cm x 5.5 cm
- 8.5 kg
- Movement Detection Technology
- Electromagnetic
- Buttons Qty
- 16
- Movement Resolution
- 5080 lpi
- Pressure sensitive pen, eraser, tilt sensitive, ExpressKeys, -/+ 60 levels tilt recognition
- Cables Included
- 1 x data cable
- Power
- AC 120/230 V
- OS Required
- Microsoft Windows Vista SP2, Apple MacOS X 10.5.8 or later, Microsoft Windows XP SP3, Microsoft Windows 7 (32/64 bits), Windows 8
- Microsoft Certification
- Compatible with Windows 7
- Digitiser
- 65 cm
- 40 cm
- 5.5 cm
- 8.5 kg
Input Device
- Wired
- Interface
- USB
- Electromagnetic
- Buttons Qty
- 16
- 5080 lpi
- Pressure Levels
- 2048
- Active Area
- 47.9 cm x 27.1 cm
Display
- LCD display
- Diagonal Size
- 21.5"
- Image Aspect Ratio
- 16:9
- Colour Support
- 16.7 million colours
- Native Resolution
- 1920 x 1080
- Image Brightness
- 230 cd/m²
- Image Contrast Ratio
- 1000:1
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Response Time
- 14 ms
- 1 x USB 2.0 - 4 pin USB Type A , 1 x display / video - DVI-Analog/Digital - DVI
- Included Accessories
- Stand, nibs (10 pcs.), USB cable, DVI-D to DVI-D cable
- Cables Included
- 1 x data cable
- C-Tick, BSMI, CB, CCC, RoHS, KCC, GOST-R, VCCI Class B, China RoHS, FCC Part 15 Class B, FCC Part 15 Class C
- Power adapter
- Voltage Required
- AC 120/230 V
- Software Included
- Drivers & Utilities
- OS Required
