Experience the power of a high-performance Cintiq in a compact, slim design. The Cintiq 13HD is an interactive pen display that allows you to create directly onto a 13.3" HD display. It offers you many of the advantages of the larger Cintiq, like the four time-saving, customizable ExpressKeys, the rocker ring, and the home button for easy shortcut access. Its high resolution HD 1920 x 1080 LED display features a 178° viewing angle and renders 16.7 million colors.
The detachable stand adjusts to three different working angles and you can also use the Cintiq 13HD flat on your desktop or in your lap. Wacom's powerful Pro Pen with 2048 levels of pressure sensitivity, tilt recognition, and a more comfortable, ergonomic design provides precise control and a better feel than ever. The Pro Pen comes in a compact carrying case that includes storage for the extra nibs and color rings that help you easily personalize and identify your pen. The Cintiq 13HD experience starts right away - with a simple setup.
High definition
The Cintiq 13HD delivers professional display performance in a compact 13.3" display. The, HD display (1920 x 1080) has wide viewing angles and renders 16.7 million colors to assure a clear image as you work. -
Compact design
The Cintiq 13HD integrates Wacom's advanced pressure-sensitive pen control, featuring 2048 levels of pen pressure, and intuitive pen tilt control in Pro Pen design. The 3-in-1 cable makes set-up to your Mac or PC as a primary or secondary display a snap.
- Wacom Cintiq 13HD - digitiser - USB
- Digitiser
- Connectivity Technology
- Wired - USB
- Display
- LCD display - 13.3" - 1920 x 1080
- Orientation
- Right and left-handed
- 37.5 cm x 1.4 cm x 24.8 cm
- 1.2 kg
- Movement Detection Technology
- Electromagnetic
- Buttons Qty
- 4
- Movement Resolution
- 5080 lpi
- Programmable buttons, pressure sensitive pen, eraser, 4 ExpressKeys, 2 side-switches, -/+ 60 levels tilt recognition, radial menu button, Rocker Ring, Precision Mode, Display Toggle
- Power
- AC 120/230 V
- OS Required
- Apple MacOS X 10.8 or later, Microsoft Windows 7 SP1 / Windows 8
- Digitiser
- Orientation
- 37.5 cm
- 1.4 cm
- 24.8 cm
- 1.2 kg
Input Device
- Wired
- Interface
- USB
- Electromagnetic
- Buttons Qty
- 4
- 5080 lpi
- Pressure Levels
- 2048
- Active Area
- 29.9 cm x 17.1 cm
Display
- LCD display
- Diagonal Size
- 13.3"
- Image Aspect Ratio
- 16:9
- Pixel Pitch
- 0.0225 mm
- Colour Support
- 16.7 million colours
- Native Resolution
- 1920 x 1080
- Image Brightness
- 250 cd/m²
- Image Contrast Ratio
- 700:1
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Response Time
- 25 ms
- 1 x USB 2.0 - 4 pin USB Type A , 1 x display / video - HDMI - 19 pin HDMI Type A , 1 x power
- Included Accessories
- Pen stand, remote control, nibs (9 pcs.), pen case, pen
- C-Tick, BSMI, CB, FCC Part 15 B, CCC, FCC Part 15 C, RoHS, KCC, GOST-R, VCCI Class B
- Voltage Required
- AC 120/230 V
- Power Consumption
- 9 Watt
- Power Consumption Stand by
- 0.5 Watt
- Software Included
- Drivers & Utilities
- OS Required
