The second generation Bamboo Stylus solo gives you the most authentic pen-like experience on touchscreens. Whether you write, doodle or navigate: it feels just natural. That is because of its perfect in-hand balance and a very slim responsive nib which is made of a unique mix of materials.
And - if you like - your Bamboo Stylus solo really stands out from the crowd. But even if you go for one of the more decent colors, it is a design statement: a stylish, clean shape with a soft-touch finish body, accented by a cap of polished anodized aluminum.
These high-quality materials at the same time ensure its durability. A Bamboo Stylus is crafted with care and thus a long-living fellow. The elegant metal cap protects the rubber nib while you carry it around. And when the nib - finally - wears off after extensive use, you can easily replace it.
- Wacom Bamboo Solo 2Gen - stylus
- Product Type
- Stylus
- Product Material
- Metal
- 0.84 cm
- Length
- 12.2 cm
- 13 g
- Black
- Product Type
- Stylus
- Product Material
- Metal
- 0.84 cm
- Length
- 12.2 cm
- 13 g
- Black
- Rubber nib, pen-like pocket clip
