Product
Brand
Wacom Bamboo Stylus feel - Carbon
Quicklinx: BHNTWS00 Mfr#: CS-400
Your ideas are an expression of yourself - and so is the style of the items you choose. The Bamboo Stylus feel carbon reflects both using the most precise technology to capture your ideas and an uncompromising quality finish of materials like carbon fiber and metal. Its active technology works with a special sensor built into a growing range of mobile devices. This combination of an active pen and fine sensor technologies provides the highest quality, most precise note-taking and sketching experience.
Designed to be properly balanced in your hand, this product gives you the precision that using your fingers on standard touch surfaces simply cannot provide.
Wacom Bamboo Stylus feel carbon - stylus
Stylus
Product Material
Metal, carbon fibre
1.06 cm
Length
14 cm
28 g
Stylus
Product Material
Metal, carbon fibre
1.06 cm
Length
14 cm
28 g
Carbon black
Pen-like pocket clip, replaceable stylus tip
