Your basket is empty
Wacom Bamboo Stylus duo3 - Blue
Quicklinx: BHNGWS00 Mfr#: CS-170B
The third-generation Bamboo Stylus duo gives you smooth performance on screen and on paper - with a unique and responsive carbon fiber nib and a high-quality ball point. It is both extremely practical and stylish. With an elegant premium design, it perfectly matches your individual style. Due to their clean curvature shape and their satined aluminum finish, they actually feel as good as they look. The unique, highly durable carbon fiber nib ensures a supremely fluid writing experience on touch screens. And should the nib ever wear out after extensive use, you can easily replace it. Compatible with media tablets, smartphones and PCs with capacitive touch screens.
Wacom Bamboo Duo 3Gen - stylus / ballpen
Stylus / ballpen
Intended for
Mobile phone, tablet
Product Material
Aluminium
0.9 cm
Length
13 cm
14.1 g
Stylus / ballpen
Intended for
Product Material
Aluminium
0.9 cm
Length
13 cm
14.1 g
Blue
Pen-like pocket clip, black ink ballpen, carbon fibre tip
