Wacom Bamboo Slate Small - A5 Graphics Tablet - Pre Order
Quicklinx: CDC5WS00 Mfr#: CDS610S
Wired / Wireless: Wireless
Compatibility: Android, Apple iOS
£84.08 ex VAT
£100.89 inc VAT
Now there's a simple, easy, and more natural way to bring your big ideas to life. Use Bamboo to transform your thoughts into powerful digital communications. Touch the pen tip to the tablet to handwrite notes, mark up digital documents, make quick sketches, and sign your name.
Combine Bamboo with Mac Inkwell or Microsoft Windows Vista and Office 2007 to handwrite email, enter text by hand anywhere typed text is accepted, navigate your desktop with a flick of the pen, and more.
Bamboo works with any software. In fact, many software applications have special features and tools that are designed to be used with a pen.
  • Write with pen on any paper, then store and share your notes in the cloud
    There's no limit to your ideas with Bamboo Slate. Write on any paper and with a push of a button convert your handwritten notes and sketches into digital files. Don't worry if you're not near your mobile device, you can store up to 100 pages on Bamboo Slate and sync later.
  • Enhance your workflow
    With the Wacom Inkspace app and your Bluetooth -enabled iOS or Android device, you can organise, edit and share your notes and sketches. Plus, you can combine pages of notes, add strokes, colour or highlights to existing notes with editable digital ink.
  • Comfortable in-hand feel
    The pen's ergonomic triangular design, soft-touch surface and pressure sensitive tip offer you a comfortable in-hand feel and perfected writing experience.
Wacom Bamboo Slate Small - digitiser - Bluetooth - medium grey with orange accents
Digitiser
Wireless - Bluetooth
Medium grey with orange accents
Orientation
Right and left-handed
18.6 cm x 0.7 cm x 24.9 cm
246 g
Movement Detection Technology
Electromagnetic
Android, Apple iOS, Windows 8.1 or later
Digitiser
Orientation
18.6 cm
0.7 cm
24.9 cm
246 g
Input Device
Wireless
Bluetooth
Electromagnetic
Pressure Levels
1024
Active Area
14 cm x 21.6 cm
Ink refills, Notepad, micro-USB cable, pen
Compatibility: Apple iOS
Brand: Wacom
Price Range Ex VAT: 50 - 100
