Vodafone Sure Signal V3
Quicklinx: C9RYWS00 Mfr#: 075375
Vodafone Sure Signal creates a 3G signal - ideal if you live in the countryside or a basement flat where it's difficult to get good reception. As it fits straight into a plug socket, Sure Signal doesn't take up much space in your home or small office. You can easily hide it away - and as it has an extra plug, you won't lose a socket either.
  • Fits in easily
  • Get up to eight people online at the same time
    You can register up to 32 numbers on your Vodafone Sure Signal, and up to eight devices can connect at once. Perfect if you have a large family, and more than one of you wants to make a call.
  • Broadband Internet
    Because Sure Signal works through your broadband Internet, it can create a 3G signal even in areas with no reception. Although it works with the majority of broadband providers and most routers, not all are compatible.
Vodafone Sure Signal - white - 3G fixed cellular terminal - UMTS
Service Provider
Vodafone
White
Fixed cellular terminal
Body Colour
White
Cellular
WCDMA (UMTS)
Mobile Broadband Generation
3G
Service Provider
Vodafone
Phone Features
Additional Features
Access Control List
