Your basket is empty
Vision TM-CAGE Medium +120mm Sides
Quicklinx: 8C91WS00 Mfr#: TM-CAGEM+120
The TM-CAGE is obvious enough to serve as an effective visual deterrent, but is unobtrusive. Just because it needs to be seen, doesn't mean it needs to be ugly! The enclosure assembles like a puzzle making it deceptively difficult to take apart.
The cage conforms as closely as possible to the size of the projector, which allows a more secure design and makes it more attractive. Security is enhanced because the projector can't be maneuvered within the enclosure to squeeze it out of an aperture, and also an attempt to cut the cage would almost certainly damage the projector.
Vision Techmount TM-CAGE Projector Security Enclosure - projector security cage
Projector security cage
Package Content
2 x keys, 8 x side panels (120 mm), 2 medium plates, 2 disk locks, 16 x foam blocks, 2 access prevention collars, hex key
Satin white
Product Material
Steel
2 years warranty
Package Content
Product Material
Steel
Satin white
Audible alarm, double lock
TUV, RoHS
