Your basket is empty
Vision TM-CAGE 100mm 8 x Side Panels
Quicklinx: 9K6MWS00 Mfr#: TM-CAGE100
Accessory Type: Projector security kit
£22.60 ex VAT
£27.12 inc VAT
The TM-CAGE is obvious enough to serve as an effective visual deterrent, but is unobtrusive. Just because it needs to be seen, doesn't mean it needs to be ugly! The enclosure assembles like a puzzle making it deceptively difficult to take apart.
The cage conforms as closely as possible to the size of the projector, which allows a more secure design and makes it more attractive. Security is enhanced because the projector can't be maneuvered within the enclosure to squeeze it out of an aperture, and also an attempt to cut the cage would almost certainly damage the projector.
Vision Techmount TM-CAGE100 - projector security kit
Package Content
8 x side panels (100 mm)
Satin white
Product Material
Steel
Package Content
Product Material
Steel
Satin white
Brand: Vision
Price Range Ex VAT: 0 - 50
