Your basket is empty
Vision TM-1200+FP Mounting Kit
Quicklinx: 9VHRWS00 Mfr#: TM-1200+FP
This adaptor replaces the spider on Vision's TM-1200 techmount allowing AV installers to safely mount flat-panel screens to ceilings. It is ideal for retail, receptions areas, pubs, or any other environment where digital signage is deployed.
Vision TM-1200+FP - ceiling mount
Ceiling mount
Tilt
Recommended Use
LCD display
Flat Panel Mount Interface
Max Load Weight
20 kg
Satin white
Satin white
AV Furniture
Ceiling mount
Mounting Components
Ceiling mount, 4 mounting adapters
Recommended Use
LCD display
Tilt
Max Load Weight
20 kg
