Lite Module Package.
This 'Lite' package suits AV installations where only simple connectivity is required. Use your own cable, or use our colour-coded pre-prepared cables select from our 10 or 15m cable packages.
Mounting Hardware Included:
1 x 2-Gang UK Backbox (surface mount)
1 x 2-Gang Surround (accomodates 5 modules)
Snap-in Modules Included:
1 x VGA with Minijack
1 x USB (B-type on front)
1 x 3-Phono
2 x Blanking panels
Plug-in cables
Modules feature plug-in connectors on the rear. Cables come pre-terminated with male connectors which are simply plugged into the rear of the module. Need to shorten or pull a cable? Just unscrew the phoenix connector. TechConnect gives you the speed of a pre-terminated system with the flexibility you sometimes need. -
Quick and easy
Simple enough that even an inexperienced technician can install it. No soldering is necessary due to its phoenix connector captive screw design. The modules are interchangeable, so if in the future you require a different connector to be installed, you can simply buy just the module you want and swap it out. -
Plug-and-Play connectivity
Unlike competing VGA cable, the quality cable has SDA and SCL data lines to support DDC2B (Display Data Channel) which allows the display device to communicate its supported display modes. Without these the user will not experience Play-and-Play connectivity and will have to manually setup resolution and color bit depth.
- VISION TechConnect 2 Lite Module Package - modular facility plate kit with snap-ins
- Product Type
- Modular facility plate kit with snap-ins - HD-15, RCA X 3, mini-phone stereo 3.5 mm, USB Type B
- Package Content
- 1 x 2-Gang UK Backbox, 1 x 2-Gang Surround, 2 blank panels, 1 x 3-Phono snap-in module, 1 x VGA with minijack snap-in module, 1 x USB (B-type on front) snap-in module
- White, RAL 9010
- RoHS, WEEE
- Limited lifetime warranty
- Product Type
- Package Content
- Enclosure Colour
- White, RAL 9010
Cabling & Wiring
- Connector Provided
- 1 x 15 pin HD D-Sub (HD-15) female , 1 x mini-phone stereo 3.5 mm female , 1 x 4 pin USB Type B female , 3 x RCA female
- Mounting Kit
- Included
- RoHS, WEEE
