Your basket is empty
Vision TechConnect V2 5m VGA Cable
Quicklinx: 9K9TWS00 Mfr#: TC2 5MVGA
Length: 5m
More than 50 in stock
£21.01 ex VAT
£25.21 inc VAT
Standard delivery Delivered within 3-5 working days
Techconnect 2 is a high-grade beige installation cable. A molded connector on one end, and a male phoenix connector on the other end which can be plugged directly into the rear of a Techconnect faceplate module.
Vision Techconnect 2 - VGA cable - 5 m
VGA cable
Molded, ferrite bead
Length
5 m
Connector
HD-15 - male
Connector (Second End)
3 x 4 pin Phoenix - male
Beige
VGA cable
Length
5 m
Beige
Connector
Length: 5m
Brand: Vision
Price Range Ex VAT: 0 - 50
