Your basket is empty
Vision TechConnect V2 5m 1-phono Cable
Quicklinx: 9K9MWS00 Mfr#: TC2 5M1PHO
Length: 5m
3 in stock
£5.62 ex VAT
£6.74 inc VAT
Standard delivery Delivered within 3-5 working days
A major cost component of cables is copper, so cheap cables have less copper and a thick outer cable jacket to fool the buyer into thinking they are getting something they are not. Compromising can result in cables which don't support high resolutions and results in flagging, image jitter and or Ghosting. The cross-sectional area of Techconnect cable conductors allows sufficient current-carrying capacity to support high resolution signal, and the shielding is evenly wound.
Need to shorten a cable or to pull a cable through a small hole or cavity? If you need 5 meter or less and no where to hide the excess cable just unscrew and remove the phoenix connector, cut the cable to length, prepare the wire ends for re-termination to the Phoenix screw connector.
VISION Techconnect 2 - video cable - 5 m
Cable
Video cable
Length
5 m
Connector
2 pin Phoenix - male
Connector (Second End)
RCA - male
Molded
Cable Type
Video cable - molded
Length
5 m
White
Connector
RCA - male
Length: 5m
Brand: Vision
Price Range Ex VAT: 0 - 50
