Your basket is empty
Vision TechConnect Matrix Control Bridge
Quicklinx: 9K7WWS00 Mfr#: TC2-MATRIXBRIDGE
Designed for video signage applications the Techconnect Matrix allows distribution of HDMI content over an existing managed LAN infrastructure. Because of this the cost of deployment is radically lower than bespoke AV distribution systems.
VISION Techconnect2 MATRIX HDMI-OVER-IP MATRIXING (Receiver and Transmitter Units) - video/audio/serial extender
Video/audio/serial extender
External
Australia, United Kingdom, United States, European Union
Remote Management Protocol
HTTP
Max Transfer Distance
100 m
AC 120/230 V
14.1 cm x 11.5 cm x 2.6 cm
440 g
2 years warranty
External
White
Wired
HTTP
Max Resolution
1920 x 1080
100 m
Status Indicators
Power over Ethernet (PoE)
HDCP 1.3
1 x HDMI - 19 pin HDMI Type A , 1 x RS-232 - terminal block
1 x serial cable
Mounting Kit
Included
TUV, EMC, RoHS, WEEE
External power adapter
5 Watt
Software Included
Drivers & Utilities
14.1 cm
11.5 cm
2.6 cm
440 g
-5 °C
35 °C
5 - 90% (non-condensing)
