Designed for video signage applications the Techconnect Matrix allows distribution of HDMI content over an existing managed LAN infrastructure. Because of this the cost of deployment is radically lower than bespoke AV distribution systems.
Matrix modes
It supports point-to-point, point-to-multiple, and multiple-to-multiple matrixing. -
MJPEG compression
It converts the video into TCP/IP packets using proprietary MPEG compression. The audio and vision are compressed together ensuring no delay issues at the receiver which may lead to out-of-sync audio on a busy network. -
RS-232
Not only can it distribute video and audio; it can also RS-232 transmit 2-way control signal to the display devices. -
Cascading network switches
The signal can be transmitted to any point on the LAN through any number of network switches. Or two devices can bypass the LAN and connect directly to each other. Note: used in this way the devices still need addressing during installation. -
HDCP compliant
Techconnect Matrix supports HDMI with full HDCP compliance. -
Power over Ethernet (PoE)
A power supply is included for each node, but the transmitters and receivers can also use standard Power over Ethernet (PoE) to operate. Many network switches output PoE, or injectors can be fitted to a network to add PoE to a network.
- VISION Techconnect2 MATRIX HDMI-OVER-IP MATRIXING Transmitter - video/audio/serial extender
- Video/audio/serial extender (transmitter)
- Form Factor
- External
- Localisation
- Australia, United Kingdom, United States, European Union
- Max Transfer Distance
- 100 m
- Power
- AC 120/230 V
- 14.1 cm x 11.5 cm x 2.6 cm
- 440 g
- 2-year warranty
- Form Factor
- External
- White
- Localisation
- Connectivity Technology
- Wired
- Max Resolution
- 1920 x 1080
- 100 m
- Power over Ethernet (PoE)
- HDCP 1.3
- 1 x HDMI - 19 pin HDMI Type A female , 1 x network - RJ-45 female , 1 x RS-232
- Power Device
- External power adapter
- Voltage Required
- AC 120/230 V (50/60 Hz)
- 5 Watt
- Software Included
- Drivers & Utilities
- 14.1 cm
- 11.5 cm
- 2.6 cm
- 440 g
- Limited warranty - 2 years
- -5 °C
- 30 °C
- 5 - 90% (non-condensing)
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
