This 'Lite' package suits AV installations where only simple connectivity is required. Use color-coded pre-prepared cables.
Plug-in cables
Modules feature plug-in connectors on the rear. Cables come pre-terminated with male connectors which are simply plugged into the rear of the module. Need to shorten or pull a cable? Just unscrew the phoenix connector. TechConnect gives you the speed of a pre-terminated system with the flexibility you sometimes need. -
Quick and easy
Simple enough that even an inexperienced technician can install it. No soldering is necessary due to its phoenix connector captive screw design. The modules are interchangeable, so if in the future you require a different connector to be installed, you can simply buy just the module you want and swap it out. -
Plug-and-Play connectivity
Unlike competing VGA cable, the quality cable has SDA and SCL data lines to support DDC2B (Display Data Channel) which allows the display device to communicate its supported display modes. Without these the user will not experience Play-and-Play connectivity and will have to manually setup resolution and color bit depth.
- VISION TechConnect 2 Lite Module Package - modular facility plate kit with snap-ins and cables
- Product Type
- Modular facility plate kit with snap-ins and cables - HD-15, RCA X 3, mini-phone stereo 3.5 mm, USB Type B
- Package Content
- 1 x 2-Gang UK Backbox, 1 x 2-Gang Surround, 1 x Minijack Cable (10m), 2 blank panels, 1 x 1-phono (RCA) composite video cable (10m), 1 x 2-phono (RCA) stereo audio cable (10m), 1 x 3-Phono snap-in module, 1 x VGA with minijack snap-in module, VGA cable (10m), 1 x USB (B-type on front) snap-in module
- White, RAL 9010
- RoHS, WEEE
- Limited lifetime warranty
- Product Type
- Package Content
- Enclosure Colour
- White, RAL 9010
Cabling & Wiring
- Connector Provided
- 1 x 15 pin HD D-Sub (HD-15) female , 1 x 4 pin USB Type B female , 3 x RCA female , 1 x mini-phone stereo 3.5 mm female
- Mounting Kit
- Included
- RoHS, WEEE
