Vision SP-2000P Active Soundbar 30w
Quicklinx: 9K6FWS00 Mfr#: SP-2000P
With a powerful 30 watt amplifier built in, the SP-2000P powered soundbar loudspeakers are designed to enhance an interactive flat-panel display. They are simple to install and sound great!
  • 6-way
    Four powerful 2" broad-band drivers provide the bass and mid-range. The proximity of the drivers provides a coupling effect to extend bass lower than it would normally go with physically small drivers. The woofers are complimented by two 1" tweeters.
  • Remote control
    A full range of options are presented on the IR remote control, including bass and treble adjustment. The same remote control comes with Vision's SP-1200P loudspeakers, and replacement remote controls are available.
  • Volume control
    A dial on the underside of the loudspeaker allows easy access to volume adjustment. A short push on the volume dial changes input, and a long push turns the power on and off.
  • Connectivity
    Two audio inputs are available on the rear panel, plus input 2 is duplicated on the underside for fast adhoc connection of portable sources such as phone and tablets.
  • Memory
    When power is connected the SP-2000P automatically comes on and remembers the previous input and volume setting. Restoring power brings the loudspeakers back to life automatically.
  • Digital
    The SP-2000P uses a quality Yamaha class-D digital amplifier chip. The amplifier circuit is constructed using surface-mount-technology techniques to ensure a long reliable life.
Vision SP-2000P - sound bar
Sound bar
Speaker Type
Active
Continuous Power
30 Watt
Frequency Response
150 - 20000 Hz
Amplifier
Integrated
Speaker Details
Sound bar - stereo x 2 - 15 Watt - 150 - 20000 Hz - 4 Ohm - active
100 cm x 8.5 cm x 8.5 cm
4.1 kg
Sound bar
Enclosure Colour
Enclosure Material
MDF
Speaker System
Speaker Type
Active
Continuous Power
30 Watt
Frequency Response
150 - 20000 Hz
Sensitivity
88 dB
Amplifier
Integrated
Controls
Power on/off, volume
Speaker System Details
Speaker Details
Sound bar - stereo x 2 - 15 Watt - 150 - 20000 Hz CFR - 4 Ohm - active
Driver Details
Sound bar: 4 x woofer driver - 2" , Sound bar: 2 x tweeter driver - 1"
Connector Type
2 x audio line-in (mini-phone stereo 3.5 mm) , Audio line-in (RCA x 2)
Power adapter, 2 brackets, IR remote control
Power Source
AC power adapter
100 cm
8.5 cm
8.5 cm
4.1 kg
