With a powerful 30 watt amplifier built in, the SP-2000P powered soundbar loudspeakers are designed to enhance an interactive flat-panel display. They are simple to install and sound great!
6-way
Four powerful 2" broad-band drivers provide the bass and mid-range. The proximity of the drivers provides a coupling effect to extend bass lower than it would normally go with physically small drivers. The woofers are complimented by two 1" tweeters. -
Remote control
A full range of options are presented on the IR remote control, including bass and treble adjustment. The same remote control comes with Vision's SP-1200P loudspeakers, and replacement remote controls are available. -
Volume control
A dial on the underside of the loudspeaker allows easy access to volume adjustment. A short push on the volume dial changes input, and a long push turns the power on and off. -
Two audio inputs are available on the rear panel, plus input 2 is duplicated on the underside for fast adhoc connection of portable sources such as phone and tablets. -
When power is connected the SP-2000P automatically comes on and remembers the previous input and volume setting. Restoring power brings the loudspeakers back to life automatically. -
Digital
The SP-2000P uses a quality Yamaha class-D digital amplifier chip. The amplifier circuit is constructed using surface-mount-technology techniques to ensure a long reliable life.
- Vision SP-2000P - sound bar
- Product Type
- Sound bar
- Speaker Type
- Active
- Continuous Power
- 30 Watt
- Frequency Response
- 150 - 20000 Hz
- Amplifier
- Integrated
- Speaker Details
- Sound bar - stereo x 2 - 15 Watt - 150 - 20000 Hz - 4 Ohm - active
- Black
- Power
- AC 120/230 V (50/60 Hz)
- 100 cm x 8.5 cm x 8.5 cm
- 4.1 kg
- 2-year warranty
- Product Type
- Sound bar
- Enclosure Colour
- Black
- Enclosure Material
- MDF
Speaker System
- Speaker Type
- Active
- Continuous Power
- 30 Watt
- 150 - 20000 Hz
- Sensitivity
- 88 dB
- Amplifier
- Integrated
- Controls
- Power on/off, volume
Speaker System Details
- Speaker Details
- Sound bar - stereo x 2 - 15 Watt - 150 - 20000 Hz CFR - 4 Ohm - active
- Driver Details
- Sound bar: 4 x woofer driver - 2" , Sound bar: 2 x tweeter driver - 1"
- Connector Type
- 2 x audio line-in (mini-phone stereo 3.5 mm) , Audio line-in (RCA x 2)
- Included Accessories
- Power adapter, 2 brackets, IR remote control
- Power Source
- AC power adapter
- Voltage Required
- 100 cm
- 8.5 cm
- 8.5 cm
- 4.1 kg
- Limited warranty - 2 years
