Product
Brand
Vision HDMI-OVER-IP TRANSMITTER AND RECEIVER SET
Quicklinx: 91XNWS00 Mfr#: TC2-HDMIIP
Part of Vision's "Techconnect Twist" product family, the TC2-HDMIIP converts HDMI signal into TCP/IP packets for transmission over a 100/10 megabit Ethernet network. With no visible loss of video or audio quality it is perfect for corporate and digital signage applications.
VISION Techconnect TC2-HDMIIP HDMI-over-IP (Receiver and Transmitter) - video/audio extender
Video/audio extender
External
Max Transfer Distance
120 m
AC 120/230 V
15 cm x 17.5 cm x 7 cm
500 g
2 years warranty
External
White
Wired
Max Resolution
1080p @ 60 Hz
120 m
HDCP compliant
1 x HDMI (input) , 1 x HDMI (output)
Mounting Kit
Included
VESA EDID, CB, RoHS, WEEE
External power adapter
Installed Qty
2
3 Watt
15 cm
17.5 cm
7 cm
500 g
-10 °C
60 °C
20 - 90%
91XN C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
91XN C2G 0.5m Select High Speed HDMI with Ethernet In Stock £6.07
91XN C2G 5m Select High Speed HDMI with Ethernet In Stock £16.55
91XN C2G 10m Select High Speed HDMI with Ethernet In Stock £32.58
91XN C2G 15m Select High Speed HDMI with Ethernet In Stock £43.69
91XN C2G Pro HDMI to VGA Converter In Stock £49.56
