Vision CS-1600 ceiling mounted speakers are passive 8-ohm low impedance speakers vision CS-1600 don't sacrifice frequency range in the way that the transformer on 100/70 V speakers inherently do, meaning lower bass extension and higher treble without distortion.
Powerful and robust 30 W power handling from the vision CS-1600 translates into loud sound with no distortion and with a frequency response of 80 Hz -20 kHz response the 2-way design offers full-bandwidth delivery with control and clarity.
Improved crossover design on the vision CS-1600 provides superb off-axis dispersion characteristics. Ceiling speakers inherently lack power at the bottom end, so Vision CS-1600 have been tuned to have a slightly louder sensitivity of 89 dB to punch through high-noise environments. The 6.5" woofer of the CS-1600 is a 6.5" polypropylene cone with a 3/4" Ferro-fluid cooled silk tweeter set in a swivel mount for fine tuning of the stereoscopic image.
The Vision CS-1600 speaker is designed for unobtrusive sound dispersion whilst mounted flush into false ceilings and ceiling tiles or deep custom made plaster board cavity walls, a perfect alternative for situations where wall speakers are not appropriate.
- Vision CS-1600 - speaker
- Product Type
- Speaker
- Packaged Quantity
- 2 (specifications are for single item)
- Speaker Type
- 2-way - passive
- Continuous Power
- 30 Watt
- Frequency Response
- 70 - 20000 Hz
- Nominal Impedance
- 8 Ohm
- Speaker System Details
- 1 x speaker 30 Watt - 70 - 20000 Hz - 8 Ohm
- White
- 12.8 cm
- Dimensions - Diameter
- 23 cm
- 1.6 kg
- Limited lifetime warranty
- Packaged Quantity
- Product Type
- Speaker
- Enclosure Colour
- White
Speaker System
- Speaker Type
- 2-way - passive
- Continuous Power
- 30 Watt
- 70 - 20000 Hz
- Nominal Impedance
- 8 Ohm
- Sensitivity
- 90 dB
- Recommended Placing
- Ceiling mountable
- Detachable Grilles
- Speakers Included
- 1 x speaker - 2-way - 30 Watt - 70 - 20000 Hz - 8 Ohm - ceiling mountable - wired
- Driver Details
- Speaker: woofer driver - 6.5" , Speaker: tweeter driver - 1" - silk
- Diameter
- 23 cm
- 12.8 cm
- 1.6 kg
Cutout & Mounting Dimensions
- Diameter
- 20 cm
