Product
Brand
Vision CS-1600 Ceiling Speakers - 30W
Quicklinx: 89CGWS00 Mfr#: CS-1600
Vision CS-1600 ceiling mounted speakers are passive 8-ohm low impedance speakers vision CS-1600 don't sacrifice frequency range in the way that the transformer on 100/70 V speakers inherently do, meaning lower bass extension and higher treble without distortion.
Powerful and robust 30 W power handling from the vision CS-1600 translates into loud sound with no distortion and with a frequency response of 80 Hz -20 kHz response the 2-way design offers full-bandwidth delivery with control and clarity.
Improved crossover design on the vision CS-1600 provides superb off-axis dispersion characteristics. Ceiling speakers inherently lack power at the bottom end, so Vision CS-1600 have been tuned to have a slightly louder sensitivity of 89 dB to punch through high-noise environments. The 6.5" woofer of the CS-1600 is a 6.5" polypropylene cone with a 3/4" Ferro-fluid cooled silk tweeter set in a swivel mount for fine tuning of the stereoscopic image.
The Vision CS-1600 speaker is designed for unobtrusive sound dispersion whilst mounted flush into false ceilings and ceiling tiles or deep custom made plaster board cavity walls, a perfect alternative for situations where wall speakers are not appropriate.
Vision CS-1600 - speaker
Speaker
Packaged Quantity
2 (specifications are for single item)
Speaker Type
2-way - passive
Nominal Output Power
30 Watt
Frequency Response
70 - 20000 Hz
Nominal Impedance
8 Ohm
Speaker System Details
1 x speaker 30 Watt - 70 - 20000 Hz - 8 Ohm
White
12.8 cm
Dimensions - Diameter
23 cm
1.6 kg
Packaged Quantity
Speaker
Enclosure Colour
White
Speaker System
Speaker Type
2-way - passive
30 Watt
Frequency Response
70 - 20000 Hz
Nominal Impedance
8 Ohm
Sensitivity
90 dB
Recommended Placing
Ceiling mountable
Detachable Grilles
Speakers Included
1 x speaker - 2-way - 30 Watt - 70 - 20000 Hz - 8 Ohm - ceiling mountable - wired
Driver Details
Speaker: woofer driver - 6.5" , Speaker: tweeter driver - 1" - silk
Diameter
23 cm
12.8 cm
1.6 kg
Cutout & Mounting Dimensions
Diameter
20 cm
