ViewSonic XG2703-GS 27" 2560 x 1440 4MS HDMI USB DP Gaming Monitor
Quicklinx: CQBRWS00 Mfr#: XG2703-GS
Diagonal Size: 27in
Max Resolution: 2560 x 1440
Response Time: 4ms
Speakers: Speaker(s)
Interfaces: DisplayPort, HDMI
10 in stock
£594.18 ex VAT
£713.01 inc VAT
The ViewSonic XG03 is the ideal display for hardcore gamers who always crank their graphics settings to Ultra, rendering every frame your GPU can output in breathtaking detail. Featuring an incredible 165Hz refresh rate, as well as NVIDIA's G-Sync Technology, this monitor's variable refresh rate capabilities virtually eliminate screen tearing and stuttering for unbelievably fluid gameplay during fast-paced action sequences. The XG03 is a juggernaut of cutting-edge display technology and features a Superclear IPS-type panel for enhanced color accuracy and greater viewing angles. A quick 4ms response time lets you seize control of the action, while a low input lag provides smooth screen performance even in the most graphic-intense sequences. For a game-winning competitive edge, a Game Mode feature optimizes visuals for FPS, RTS and MOBA. On top of that, a dark color enhancement function helps you target enemies lurking in the dark, while the monitor maintains brilliantly rich colors and contrast. With a gamer-inspired ergonomic stand that features an integrated headphone hook and cable management functionality, the XG03 has all you need to conquer your gaming quests.
  • Quad HD resolution
    At four times the resolution of a traditional 720p panel, and almost double that of a traditional 1080p display, QHD results in a much sharper image, with no distortion or stretching, all while maintaining a 16:9 aspect ratio. QHD resolution also provides up to 77% more screen space for a more immersive experience.
  • 165Hz refresh rate
    With a swift 165Hz refresh rate, this monitor delivers greater visual fluidity and awesome graphics no matter how quickly the in-game action unfolds. Say goodbye to annoying tracers and motion blur, and up your A-game with the smoothest visuals possible.
  • SuperClear IPS-type panel technology
    Enjoy accurate and vivid colors with consistent levels of brightness no matter the vantage point. With SuperClear IPS-type panel technology, this monitor delivers the same image quality whether you are looking at the screen from above, below, the front, or the side.
  • NVIDIA G-Sync technology
    NVIDIA G-SYNC technology seamlessly synchronizes the frame rate output between your graphics card and monitor. This eliminates screen tearing, and minimizes stutter and input lag for the most breathtaking gameplay experience.
  • NVIDIA ultra low motion blur technology
    Experience smooth movement and sharp edges in even the most action-packed gaming scenarios. NVIDIA Ultra Low Motion Blur (ULMB) decreases motion blur and minimizes ghosting when the on-screen action gets heated. So whether you're racing, shooting, or strategizing, the images on screen remain as sharp and smooth as your own reflexes.
  • Versatile connectivity
    DisplayPort, HDMI, and VGA inputs give you the freedom and flexibility to connect to your dedicated graphics card and gaming console.
ViewSonic XG Gaming XG2703-GS - LED monitor - 27"
LED-backlit LCD monitor - 27"
Adaptive-Sync Technology
NVIDIA G-SYNC
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
2560 x 1440
Brightness
350 cd/m²
Contrast Ratio
1000:1 / 120000000:1 (dynamic)
Response Time
4 ms (grey-to-grey)
Input Connectors
HDMI, DisplayPort
Display Position Adjustments
62.44 cm x 25.04 cm x 53.24 cm
7 kg
Europe
Environmental Standards
ENERGY STAR Qualified
FCC Class B certified, ICES-003, CB, CCC, DOC, RoHS, WEEE, cULus, REACH, ERP, SVHC, CoC, NRCAN, CE/EMC
Display Type
Diagonal Size
27"
NVIDIA G-SYNC
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
2560 x 1440
Brightness
350 cd/m²
Contrast Ratio
Response Time
4 ms (grey-to-grey)
Vertical Refresh Rate
24 - 165 Hz
Horizontal Refresh Rate
15 - 209 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
SuperClear, game mode, 100% sRGB colour gamut, Flicker Free technology, NVIDIA Ultra Low Motion Blur Technology, 6-axis colour adjustment, Low Input Lag, Bluelight Filter
62.44 cm x 25.04 cm x 53.24 cm - with stand
7 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
DisplayPort , HDMI , USB 3.0 upstream (Type B) , Headphones (mini-jack) , 2 x USB 2.0 downstream (Type A) , 2 x USB 3.0 downstream (Type A)
Mechanical
Tilt Angle
-5/+15
Swivel Angle
350
Rotation Angle
90
Height Adjustment
100 mm
VESA Mounting Interface
100 x 100 mm
1 x DisplayPort cable - 1.5 m , 1 x SuperSpeed USB cable - 1.5 m
Europe
48 Watt
Dimensions & Weight Details
Without stand - width: 62.44 cm - depth: 7.86 cm - height: 38.36 cm - weight: 4 kg , With stand - width: 62.44 cm - depth: 25.04 cm - height: 53.24 cm - weight: 7 kg
ENERGY STAR Certified
20 - 90% (non-condensing)
ViewSonic XG2703-GS 27 Bundle deal on ViewSonic XG2703-GS 27" 2560 x 1440 4MS HDMI USB DP Gaming Monitor
£693.94
Diagonal Size: 27in
Response Time: 4ms
Interfaces: HDMI
Brand: ViewSonic
Price Range Ex VAT: 500 - 750
