ViewSonic VX3276-MHD 32" 1920x1080 3ms HDMI, VGA, DisplayPort LED Monitor
Quicklinx: DKX7WS00 Mfr#: VX3276-MHD-2
Diagonal Size: 32in
Max Resolution: 1920 x 1080
Response Time: 3ms
Speakers: Speaker(s)
Interfaces: DisplayPort, HDMI, VGA (HD-15)
£157.38 ex VAT
£188.85 inc VAT
The ViewSonic VX3276-mhd-2 is the perfect blend of style and performance with features that include a sizeable 32" (31.5" viewable) panel, a minimalist design, metallic silver triangle stand, and a sleek edge-to-edge frameless bezel give the monitor a premium feel that fits nicely both at home and in the office. VX3276-mhd-2 features 1080p resolution, SuperClear IPS technology and dual integrated speakers to produce astonishing visual and sound effect from multimedia contents.
ViewSonic VX3276-MHD-2 - LED monitor - Full HD (1080p) - 32"
LED-backlit LCD monitor - 32"
Energy Class
Class A
Energy Consumption per Year
52 kWh
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.364 mm
Brightness
250 cd/m²
Contrast Ratio
1200:1 / 80000000:1 (dynamic)
Response Time
3 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
Black, silver
71.289 cm x 23 cm x 50.387 cm
6.2 kg
DDC-2B, ISO 13406-2, DDC/CI, WEEE, REACH, UkrSEPRO, ERP, EuP, EAC, CU, DisplayPort 1.2
3-year warranty
Display Type
Energy Class
Class A
52 kWh
Diagonal Size
32"
Viewable Size
31.5"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.364 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
3 ms (grey-to-grey)
Vertical Refresh Rate
50 - 75 Hz
Horizontal Refresh Rate
24 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
Ultra Slim Design, HDCP, SuperClear, Eco-Mode, edge-to-edge glass, Low Blue Light Mode, Flicker Free technology, Transition Minimised Differential Signaling (TMDS) technology, 75% NTSC colour gamut, frameless bezel design, ViewMode
Black, silver
71.289 cm x 23 cm x 50.387 cm - with stand
6.2 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
DisplayPort , HDMI , VGA , Audio line-in (mini-jack) , Audio line-out (mini-jack)
Mechanical
Tilt
Tilt Angle
-4/+15
VESA Mounting Interface
100 x 100 mm
1 x HDMI cable
Security Slot Type
Kensington security slot
AC 100 - 240 V (50 - 60 Hz)
36 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.3 Watt
Included Software
ViewSonic ViewSplit
Dimensions & Weight Details
Without stand - width: 71.289 cm - depth: 3.82 cm - height: 41.64 cm - weight: 5.6 kg , With stand - width: 71.289 cm - depth: 23 cm - height: 50.387 cm - weight: 6.2 kg
Shipping Width
78.5 cm
Shipping Depth
11.2 cm
Shipping Height
49.8 cm
Shipping Weight
8.2 kg
Limited warranty - 3 years
20 - 90% (non-condensing)
ViewSonic VX3276-MHD 32 Bundle deal on ViewSonic VX3276-MHD 32" 1920x1080 3ms HDMI, VGA, DisplayPort LED Monitor
£248.92
Diagonal Size: 32in
Response Time: 3ms
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: ViewSonic
Price Range Ex VAT: 150 - 300
