The ViewSonic VX3276-mhd-2 is the perfect blend of style and performance with features that include a sizeable 32" (31.5" viewable) panel, a minimalist design, metallic silver triangle stand, and a sleek edge-to-edge frameless bezel give the monitor a premium feel that fits nicely both at home and in the office. VX3276-mhd-2 features 1080p resolution, SuperClear IPS technology and dual integrated speakers to produce astonishing visual and sound effect from multimedia contents.
- ViewSonic VX3276-MHD-2 - LED monitor - Full HD (1080p) - 32"
- LED-backlit LCD monitor - 32"
- Energy Class
- Class A
- Energy Consumption per Year
- 52 kWh
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Pixel Pitch
- 0.364 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1200:1 / 80000000:1 (dynamic)
- Response Time
- 3 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, VGA, DisplayPort
- Tilt
- Screen Coating
- Anti-glare
- Black, silver
- 71.289 cm x 23 cm x 50.387 cm
- 6.2 kg
- DDC-2B, ISO 13406-2, DDC/CI, WEEE, REACH, UkrSEPRO, ERP, EuP, EAC, CU, DisplayPort 1.2
- 3 years warranty
- Display Type
- Energy Class
- Class A
- 52 kWh
- Diagonal Size
- 32"
- Viewable Size
- 31.5"
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.364 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- Vertical Refresh Rate
- 50 - 75 Hz
- Horizontal Refresh Rate
- 24 - 83 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Anti-glare
- Backlight Technology
- LED backlight
- Ultra Slim Design, HDCP, SuperClear, Eco-Mode, edge-to-edge glass, Low Blue Light Mode, Flicker Free technology, Transition Minimised Differential Signaling (TMDS) technology, 75% NTSC colour gamut, frameless bezel design, ViewMode
- Black, silver
- 71.289 cm x 23 cm x 50.387 cm - with stand
- 6.2 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 2 Watt
- DisplayPort , HDMI , VGA , Audio line-in (mini-jack) , Audio line-out (mini-jack)
Mechanical
- Tilt
- Tilt Angle
- -4/+15
- Flat Panel Mount Interface
- 100 x 100 mm
- Cables Included
- 1 x HDMI cable
- Security Slot Type
- Kensington security slot
- Voltage Required
- AC 100 - 240 V (50 - 60 Hz)
- 36 Watt
- Power Consumption Stand by
- 0.5 Watt
- 0.3 Watt
- Included Software
- ViewSonic ViewSplit
- Dimensions & Weight Details
- Without stand - width: 71.289 cm - depth: 3.82 cm - height: 41.64 cm - weight: 5.6 kg , With stand - width: 71.289 cm - depth: 23 cm - height: 50.387 cm - weight: 6.2 kg
- Shipping Width
- 78.5 cm
- Shipping Depth
- 11.2 cm
- Shipping Height
- 49.8 cm
- Shipping Weight
- 8.2 kg
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 20 - 90% (non-condensing)
Bundle includes:
Microsoft Office 365 Business Premium ‘in a box’ 1 year subscription/license worth £96.99 | in stock |
£252.53
