ViewSonic VX2476-SMHD 24" 1920 x 1080 4ms VGA HDMI DP LCD Monitor
Quicklinx: CQBFWS00 Mfr#: VX2476-SMHD
Diagonal Size: 24in
Max Resolution: 1920 x 1080
Response Time: 4ms
Speakers: Speaker(s)
Interfaces: DisplayPort, HDMI, VGA (HD-15)
More than 50 in stock
£118.47 ex VAT
£142.16 inc VAT
24 inch stylish frameless IPS monitor with HDMI, DisplayPort and speakers.
  • Frameless bezel design
    Break free from bulky designs, and prepare for a frameless experience. An ultra slim 6.6 mm panel and a thin 2 mm bezel, delivering an incredible visual experience.
  • Stunning color performance & wide-angle viewing
    With SuperClear IPS panel technology, enjoy accurate and vivid colors with consistent levels of brightness whether you are looking at the screen from above, below, the front, or the side.
  • Full HD 1080p resolution
    This monitor features Full HD 1920x1080 resolution for unbelievable pixel-by-pixel image performance. You'll experience the most amazing clarity and detail whether while working, gaming, or enjoying the latest in multimedia entertainment.
  • Flexible connectivity
    HDMI, DisplayPort and VGA inputs, enable users to connect to game consoles, Blu-ray players, digital cameras, laptops, satellite boxes, and other high-definition devices.
  • Enhanced viewing comfort
    Flicker-Free technology and a Blue Light Filter help to eliminate eye strain from extended viewing periods.
ViewSonic VX2476-smhd - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class A
Energy Consumption per Year
31 kWh
Power Consumption (On mode)
21 W
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 80000000:1 (dynamic)
Response Time
4 ms (grey-to-grey)
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Tilt
Silver
54 cm x 20.9 cm x 41.4 cm
2.97 kg
Environmental Standards
ENERGY STAR Qualified
UL, BSMI, CB, CCC, FCC, RoHS, WEEE, REACH, ERP, CU
(Austria, Germany, Switzerland - 2 years)
Display Type
Energy Class
Class A
31 kWh
21 W
Diagonal Size
24"
Viewable Size
23.8"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
Response Time
4 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
SuperClear, game mode, Flicker Free technology, Blue Light Filter technology, Wide Viewing Angle, Movie Mode, text mode, web mode, mono mode, frameless bezel design, Low Input Lag
Silver
54 cm x 20.9 cm x 41.4 cm - with stand
2.97 kg
Audio
Speakers - stereo
Output Power / Channel
3 Watt
HDMI , DisplayPort , VGA , Headphones , Audio line-in
Mechanical
Tilt
Tilt Angle
-5/+17
1 x VGA cable , 1 x audio cable
Security Slot Type
Kensington security slot
Power Consumption Stand by
0.3 Watt
Power Consumption (Off Mode)
0.3 Watt
Dimensions & Weight Details
Without stand - width: 54 cm - depth: 3.4 cm - height: 32.3 cm - weight: 2.53 kg , With stand - width: 54 cm - depth: 20.9 cm - height: 41.4 cm - weight: 2.97 kg
ENERGY STAR Certified
20 - 90% (non-condensing)
ViewSonic VX2476-SMHD 24 Bundle deal on ViewSonic VX2476-SMHD 24" 1920 x 1080 4ms VGA HDMI DP LCD Monitor
£217.64
Diagonal Size: 24in
Response Time: 4ms
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: ViewSonic
Price Range Ex VAT: 100 - 150
