ViewSonic VX2475SMHL-4K 23.6" 3840x2610 2ms HDMI LED 4K Monitor
DELIVERS STUNNING DEFINITION FOR MULTIMEDIA ENTERTAINMENT!
Quicklinx: BDYQWS00 Mfr#: VX2475SMHL-4K
The ViewSonic VX2475Smhl-4K is a 24" Ultra HD LED monitor that delivers stunning definition for multimedia entertainment. With 4K resolution, 100% sRGB coverage, SuperClear PLS technology for wide-angle viewing, 2ms response time, and an amazing 120M: 1 dynamic contrast ratio, this monitor provides incredible images and lifelike video playback. Future-proof connectivity features include DisplayPort 1 2a and MHL for easy and flexible viewing options of high-definition content, while HDMI2.0 supports crystal-clear 4K content at a 60 Hz signal. Dual integrated 2W speakers deliver immersive sound for the ultimate multimedia experience. ViewSonic' s exclusive ViewMode provides intuitive presets to deliver optimized screen performance in different applications.
  • Stunning Ultra HD resolution
    With four-times more pixels than Full HD resolution, this Ultra HD monitor displays more content and maximizes productivity while delivering the ultimate in image detail and clarity.
  • SuperClear IPS-Type panel technology with wide viewing angles
    SuperClear IPS-Type panel technology delivers accurate and vivid colors with consistent levels of brightness whether looking at the screen from above, below, the front, or the side - with no color distortion or decay.
  • Reviving Color with 100% sRGB color coverage
    Accurate and consistent color performance is essential for professionals in graphic design, video editing, and other professional environments. With 100% sRGB color coverage capability, the VX2475Smhl-4K reproduces 100% sRGB rich color performance and captures images in their original and true colors.
  • HDMI 2.0 and DisplayPort 1.2 supports Ultra HD resolution at 60 Hz
    This monitor features HDMI 2.0 and DisplayPort 1.2 future-proof video standards and supports 3840x2160 resolution at 60 Hz frame rate, guaranteeing true Ultra HD picture clarity.
  • Versatile connectivity for mobile, peripheral, and storage devices
    Integrated with MHL, this monitor enables users to connect high definition and compatible mobile devices, such as smartphones and tablets, directly to the monitor.
  • ViewSonic flicker-free technology
    Rather than using Pulse Width Modulation that continuously turns the LED backlight on and off, ViewSonic flicker-free monitors use DC modulation backlights that maintain a steady stream of direct current power - nearly eliminating screen flickering at all brightness levels by providing a constant LED light source.
  • Blue Light Filter for more comfortable viewing
    ViewSonic monitors feature a Blue Light Filter setting that allows users to adjust the amount of blue light emitted from the screen, enabling longer viewing times and increased eye comfort for work and multimedia applications.
ViewSonic VX2475Smhl-4K - LED monitor - 24"
LED-backlit LCD monitor - 24"
Aspect Ratio
Widescreen
Native Resolution
4K 3840 x 2160 ( DisplayPort: 60 Hz, HDMI: 60 Hz )
Brightness
300 cd/m2
Contrast Ratio
1000:1 / 12000000:1 (dynamic)
Response Time
2ms (grey-to-grey)
Input Connectors
2xHDMI, DisplayPort, MHL
Speakers
Integrated
Display Position Adjustments
Tilt
Screen Coating
Anti-glare, 3H Hard Coating
56.64 cm x 23.15 cm x 43.55 cm - with stand
4.6 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
Display Type
LED-backlit LCD monitor / Plane to Line Switching (PLS)
Diagonal Size
24"
Viewable Size
23.6"
Aspect Ratio
Widescreen
Native Resolution
Brightness
300 cd/m2
Contrast Ratio
Response Time
4.1 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
WLED
SuperClear, Eco-Mode, 100% sRGB colour gamut, Flicker Free technology, Mobile High-Definition Link (MHL) 2.0, Mercury free, Transition Minimised Differential Signaling (TMDS) technology, Blue Light Filter technology
4.6 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
3 Watt
MHL / HDMI , HDMI , DisplayPort , Audio line-out
Mechanical
Tilt
Tilt Angle
-5/+22
Flat Panel Mount Interface
100 x 100 mm
Power Supply
Internal
AC 120/230 V ( 50/60 Hz )
32 Watt
Dimensions & Weight Details
With stand - width: 56.64 cm - depth: 23.15 cm - height: 43.55 cm - weight: 4.6 kg , Without stand - width: 56.64 cm - depth: 4.8 cm - height: 35.66 cm - weight: 3.7 kg
