ViewSonic VX2363SMHL-W 23" 1920x1080 2ms VGA HDMI IPS Monitor
Quicklinx: 9SN1WS00 Mfr#: VX2363SMHL-W
The ViewSonic VX2363SMHL-W is a 23" Full HD 1080p display designed for entertainment, gaming, and multimedia applications. An MHL port enables seamless connectivity, and simultaneous battery charging, of MHL-enabled mobile devices to facilitate easy content sharing and mobile gaming on a larger screen. Additional versatile connectivity options include HDMI and VGA ports for added convenience in traditional PC environments. In addition, ViewSonic's SuperClear image enhancement technology delivers superior color performance with excellent color reproduction, while a 50M:1 MEGA dynamic contrast ratio and integrated stereo speakers provide great multimedia and entertainment performance. Additional features include Eco-mode for increased energy savings, as well as a 100 x 100 mm VESA mount for more flexible installation options. A premium design includes a frameless edge-to-edge glass faceplate and slim bezel beneath the glass, making the VX2363SMHL-W a stylish addition to any desktop.
  • Full HD 1080p for superior pixel performance
    The ViewSonic VX2363SMHL-W features Full HD 1920 x 1080 resolution for unbelievable pixel-by-pixel image performance. You'll experience the most amazing clarity and detail whether it be while gaming or enjoying the latest in multimedia entertainment. A 16:9 widescreen ratio minimizes eye fatigue even after hours of playtime, and is perfectly compatible with multi-window viewing without toggling.
  • MHL functionality for easy connection to mobile devices
    Integrated with Mobile High-Definition Link (MHL), the VX2363SMHL-W enables users to connect compatible mobile devices directly to the VX2363SMHL-W display. This allows digital content from mobile devices to be viewed in stunning Full HD resolution on the larger screen of the VX2363SMHL-W, while also simultaneously charging the batteries of the mobile device. To toggle between inputs, simply press the "2" button located on the bottom edge of the screen.
  • Dual HDMI inputs for diverse Full HD connectivity
    HDMI is the highest, future-proof video standard, guaranteed for true digital picture clarity. Equipped with two sets of HDMI inputs, the VX2363SMHL-W display allows you to connect to a variety of HD devices including gaming consoles, Blu-ray players, laptop PCs, digital cameras, and many others for the ultimate true high-definition experience.
  • SuperClear Image Enhancement technology with wide viewing angles
    SuperClear Image Enhancement technology delivers the best color performance and extends display viewing angles to 178 degrees both horizontally and vertically. Experience accurate and vivid colors with consistent levels of brightness whether looking at the screen from above, below, the front, or the side - with no color distortion or decay.
  • Frameless design with edge-to-edge glass
    Say goodbye to the thick, clunky plastic frames set over the edges of traditional monitors. The VX2363SMHL-W features a frameless edge-to-edge glass faceplate with an ultra-slim bezel beneath the glass. With its sleek, eye-catching design, this elegant IPS monitor looks as good as it performs.
  • Eco-mode conserves more energy and cuts costs
    ViewSonic's proprietary Eco-mode energy-saving feature is built into all LED displays, offering "optimize (85%)" or "conserve (70%)" settings that save up to 25% in electricity costs. In low ambient light, Eco-mode adjusts brightness and improves visibility, while reducing eye fatigue. With Eco-mode, the lifespan of the LED backlighting is also greatly increased.
  • Dual integrated stereo speakers
    The ViewSonic VX2363SMHL-W has two integrated 2 W stereo speakers for enhanced multimedia performance with crystal-clear stereo sound.
  • VESA-mountable
    The ViewSonic VX2363SMHL-W features a 100 x 100 mm VESA-mountable design that allows you to mount the display on a monitor stand or on a wall, depending on your specific needs. You can easily unscrew the base, and then mount the display on its stand or wall mount.
ViewSonic VX2363SMHL-W - LED monitor - Full HD (1080p) - 23"
LED-backlit LCD monitor - 23"
Energy Class
Class A
Energy Consumption per Year
30 kWh
Power Consumption (On mode)
20 W
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 50000000:1 (dynamic)
Response Time
2 ms (gray-to-gray)
Input Connectors
2xHDMI, VGA
Speakers
Integrated
Display Position Adjustments
Tilt
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
White
53.19 cm x 16.4 cm x 40.58 cm
3.2 kg
Environmental Standards
ENERGY STAR Qualified
FCC Class B certified, UL, ICES-003, NOM
3-year warranty
Display Type
Energy Class
Class A
30 kWh
Diagonal Size
23"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
Response Time
2 ms (gray-to-gray)
Vertical Refresh Rate
50 - 75 Hz
Horizontal Refresh Rate
24 - 82 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
WLED
Controls & Adjustments
Brightness, contrast, input select
SuperClear, Eco-Mode, frameless, Mega Dynamic Contrast Ratio, Mobile High-Definition Link (MHL), edge-to-edge glass
White
53.19 cm x 16.4 cm x 40.58 cm - with stand
3.2 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
1.5 Watt
VGA , 2 x HDMI , Audio line-in , Audio line-out
Mechanical
Tilt
Tilt Angle
-5/+15
VESA Mounting Interface
100 x 100 mm
1 x VGA cable , 1 x HDMI cable , 1 x audio cable
Backlight Life
30,000 hours
Security Slot Type
Kensington security slot
Power Supply
External
Input Voltage
20 W
Power Consumption (Typical)
21 Watt
On / Off Switch
No
Included Software
ViewSonic Wizard
Dimensions & Weight Details
With stand - width: 53.19 cm - depth: 16.4 cm - height: 40.58 cm - weight: 3.2 kg , Without stand - width: 53.19 cm - depth: 4.1 cm - height: 33.05 cm - weight: 2.9 kg
Sustainability Information
ENERGY STAR Certified
Limited warranty - parts and labour - 3 years , Limited warranty - backlight - 3 years
10 - 90% (non-condensing)
