ViewSonic VX2363smhl 23" 1920x1080 2ms VGA MHL HDMI IPS LED Monitor
Quicklinx: BDP8WS00 Mfr#: VX2363smhl
The ViewSonic VX2363Smhl is a 23" Full HD multimedia display with HDMI and MHL / HDMI connectivity to connected with various high definition devices and mobile devices. Featuring SuperClear IPS technology, 178 degrees wide viewing angle and 95% sRGB color coverage delivers phenomenal color performance. ClearMotiv ultra-fast 2ms GTG(s) response times, ViewMode and dual speakers ensures best audio and video quality for movie and gaming. Featuring Flicker-Free and Blue Light Filter eye-care technology, ECO mode, a premium frameless bezel in glossy black finish and VESA-compliant design, VX2363SMHL makes a great addition to any home and office.
  • SuperClear IPS Image Enhancement Technology with 95% sRGB coverage and wide viewing angles
    SuperClear Image Enhancement Technology delivers the best color performance and extends display viewing angles to 178 degrees both horizontally and vertically. Experience accurate and vivid colors with consistent levels of brightness whether looking at the screen from above, below, the front, or the side - with no color distortion or decay.
  • ClearMotiv II ultra-fast 2ms response times for blur-free action
    ViewSonic's exclusive ClearMotiv II imaging technology delivers ultra-fast 2 millisecond liquid crystal response times, creating smooth images without streaking, blurring or ghosting. This blazing-fast response time is perfect for the most graphic-intense gaming needs, and just as great for watching sports or action movies.
  • MHL functionality for easy connection to mobile devices
    Integrated with Mobile High-Definition Link (MHL), the VX2363Smhl enables users to connect compatible mobile devices, such as smartphones and tablets, directly to the monitor. This allows digital content from mobile devices to be viewed in stunning Full HD resolution on the larger screen of the VX2363Smhl, while also simultaneously charging the batteries of the mobile device.
  • Dual HDMI inputs for diverse Full HD connectivity
    HDMI is the highest, future-proof video standard, guaranteed for true digital picture clarity. Equipped with two sets of HDMI inputs, the VX2363Smhl display allows you to connect to a variety of HD devices including gaming consoles, Blu-ray players, laptop PCs, digital cameras, and many others for the ultimate true high-definition experience.
  • Dual integrated stereo speakers
    The ViewSonic VX2363Smhl has two integrated 2W stereo speakers for enhanced multimedia performance with crystal-clear stereo sound.
  • Full HD 1080p for Superior Pixel Performance
    The ViewSonic VX2363Smhl features Full HD 1920x1080 resolution for amazing clarity and detail whether it be while gaming or enjoying the latest in multimedia entertainment. A 16:9 widescreen ratio shows more images than conventional 5:4 screen and minimizes eye fatigue.
  • Sleek Frameless Bezel Design
    The distinctive and stylish ViewSonic's VX2363Smhl fuses a frameless bezel design into stylish black glossy design, making it a great addition to your home. In addition, the frameless design provides a seamless multi-screen viewing experience.
  • Game Mode for Higher Visibility in Dark Scenes
    With just the press of a button, gain a competitive edge when playing your favorite video games. Game Mode provides enhanced visibility and detail by highlighting dark scenes without over-exposing the bright areas. This lets you see your opponents' every move, even in the darkest scenes of a video game.
  • Eco-mode conserves more energy and cuts costs
    ViewSonic's proprietary Eco-mode energy-saving feature is built into all LED displays, offering "Optimize (75%)" or "Conserve (50%)" settings that save up to 25% of electricity costs. In low ambient light, Eco-mode adjusts brightness and improves visibility, while reducing eye fatigue. With Eco-mode, the lifespan of the LED backlighting is also greatly increased.
  • Better color accuracy with color management
    ViewSonic's built-in color management system maintains strict standards for color temperature and white balance correction to ensure the most accurate white level for image rendering. Different OSD color settings (Bluish, Cool, Native, Warm) allow you to match different color temperature settings and create a more comfortable working environment - wherever you are. Calibrated to be 100% consistent from screen-to-screen, each monitor displays the exact same colors and sRGB settings as your original HD-device source images.
Display Type
Energy Class
Class A
Energy Consumption per Year
30 kWh
Power Consumption (On mode)
21 W
Diagonal Size
23"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 50000000:1 (dynamic)
Colour Support
16.7 million colours
Response Time
2 ms (gray-to-gray)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Controls & Adjustments
Brightness, contrast, input select
SuperClear, Eco-Mode, frameless, ClearMotiv II, game mode, Mobile High-Definition Link (MHL), Flicker Free technology, Blue Light Filter technology
53.19 cm x 16.4 cm x 40.58 cm - with stand
3.2 kg
Audio
Speakers - stereo
Output Power / Channel
1.5 Watt
VGA , HDMI , MHL / HDMI , Audio line-in , Audio line-out
Mechanical
Display Position Adjustments
Tilt
Tilt Angle
-5/+15
VESA Mounting Interface
100 x 100 mm
1 x VGA cable , 1 x HDMI cable , 1 x audio cable
UL, CB, EMC, FCC, RoHS, UkrSEPRO, ERP
Security Slot Type
Kensington security slot
Power Consumption Stand by
0.2 Watt
Power Consumption (Off Mode)
0.2 Watt
Included Software
ViewSonic Wizard
Dimensions & Weight Details
With stand - width: 53.19 cm - depth: 16.4 cm - height: 40.58 cm - weight: 3.2 kg , Without stand - width: 53.19 cm - depth: 4.1 cm - height: 33.05 cm - weight: 2.9 kg
Environmental Standards
ENERGY STAR Certified
10 - 90% (non-condensing)
