ViewSonic's VX2252MH is a 22" (21.5" viewable) Full HD, glossy-finish display that offers the ultimate visual experience for gaming and multimedia entertainment. The VX2252MH features ClearMotiv II technology that delivers 2 ms ultra-fast response time for blur-free images during extreme gaming, and an ultra-high 50M:1 MEGA dynamic contrast ratio for sharp, crisp color performance for enjoying movies. Integrated D-sub, DVI and HDMI inputs provide flexible connectivity for high-definition multimedia devices and gaming consoles, and dual built-in 2 W stereo speakers complete the package for multimedia enjoyment. With a VESA-mountable design, the VX2252MH offers flexible mounting options for any of your gaming and video entertainment needs.
Blazing-fast response time for blur-free action
ViewSonic's exclusive ClearMotiv II imaging technology delivers ultra-fast 2 millisecond liquid crystal response times, creating smooth images without streaking, blurring or ghosting. This blazing-fast response time is perfect for the most graphic-intense gaming needs, and just as great for watching sports or action movies. Enjoy blur-free digital broadcasts and full-motion graphics. -
Stunning resolution and clarity
The VX52 series of displays feature Full HD 1920 x 1080 resolution for unbelievable pixel-by-pixel image performance. You'll experience the most amazing clarity and detail whether it be while gaming or enjoying the latest in multimedia entertainment. -
Game mode
ViewSonic's game mode provides heightened visibility and detail by brightening dark scenes. Dominate the competition with enhanced visibility, even in the darkest scenes of a video game. With just the press of a button, ViewSonic's game mode delivers superior color performance for the ultimate gaming experience. -
MEGA dynamic contrast ratio for sharp, crisp images
A superior dynamic contrast ratio of 50M:1 better defines the relationship between the darkest and brightest colors, ensuring all displayed images are rich and detailed. -
Flexible HDMI connectivity
HDMI is the highest, future-proof video standard, guaranteed for true digital picture clarity. The HDMI interface on the VX2252MH allows you to connect to a variety of HD devices including gaming consoles, Blu-ray players, laptop PCs, digital cameras, and many others for the ultimate true high-definition experience. -
ENERGY STAR certified and mercury-free LED backlighting
LED backlighting enhances display performance, delivers an outstanding color range, and adjusts contrast ratios for remarkably detailed images. The LED backlighting further conserves up to 25% more energy when compared to conventional displays. In addition, a slim, lightweight profile saves desktop space. -
Eco-mode conserves more energy
ViewSonic's proprietary eco-mode function comes standard with the VX2252MH display. It offers 85% and 75% "optimize" and "conserve" modes based on the users' working scenarios. Both modes reduce display brightness and conserve energy by up to 25%. In low ambient lighting, this function adjusts brightness to improve visibility and reduce eye fatigue. Eco-mode prolongs the monitor's lamp life, improving your return on investment. -
Dual integrated 2 W speakers
The VX2252MH has two integrated speakers for enhanced multimedia performance with crystal-clear stereo sound. -
The VX2252MH features a 100 x 100 mm VESA-mountable design that allows you to mount the display on a monitor stand or on a wall, depending on your specific needs. You can easily detach the base by unscrewing four screws and then mounting the display on its stand or wall mount.
- ViewSonic VX2252MH - LED monitor - Full HD (1080p) - 22"
- LED-backlit LCD monitor - 22"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 50000000:1 (dynamic)
- Response Time
- 2 ms (gray-to-gray)
- Input Connectors
- HDMI, DVI-D, VGA
- Speakers
- Integrated
- Tilt
- Screen Coating
- Anti-glare, 3H Hard Coating
- Voltage
- AC 120/230 V (50/60 Hz)
- 51.11 cm x 22.25 cm x 40.2 cm
- 3.3 kg
- Localisation
- Americas
- Environmental Standards
- ENERGY STAR Qualified
- FCC Class B certified, UL, ICES-003, CB, EMC, DOC, RoHS, WEEE, cULus, REACH, UkrSEPRO, ERP, EAC, SVHC, Mexico CoC
- Display Type
- Diagonal Size
- 22"
- Viewable Size
- 21.5"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Brightness
- 250 cd/m²
- Contrast Ratio
- Response Time
- Vertical Refresh Rate
- 50 - 75 Hz
- Horizontal Refresh Rate
- 24 - 82 kHz
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Screen Coating
- Backlight Technology
- LED backlight
- Controls & Adjustments
- Brightness, contrast, colour balance, input select
- Eco-Mode, ClearMotiv II, game mode, Mega Dynamic Contrast Ratio
- 51.11 cm x 22.25 cm x 40.2 cm - with stand
- 3.3 kg
Audio
- Speakers - stereo - integrated
- Output Power / Channel
- 2 Watt
- VGA , HDMI , DVI-D (HDCP) , Audio line-in (mini-jack) , Headphones (mini-jack)
Mechanical
- Tilt
- Tilt Angle
- 20
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x VGA cable , 1 x DVI cable , 1 x audio cable
- Backlight Life
- 30,000 hours
- Localisation
- Americas
- Security Slot Type
- Kensington security slot
- Power Supply
- External
- Input Voltage
- Power Consumption (Typical)
- 22 Watt
- Included Software
- ViewSonic Wizard
- Dimensions & Weight Details
- With stand - width: 51.11 cm - depth: 22.25 cm - height: 40.2 cm - weight: 3.3 kg , Without stand - width: 51.11 cm - depth: 5.3 cm - height: 32.72 cm - weight: 2.9 kg
- Shipping Width
- 56 cm
- Shipping Depth
- 12.8 cm
- Shipping Height
- 45.2 cm
- Shipping Weight
- 4.8 kg
Sustainability Information
- ENERGY STAR Certified
- ENERGY STAR Version
- 7.0
- 0 °C
- 40 °C
- 20 - 90% (non-condensing)
