Product
Brand
ViewSonic VX2252MH 21.5" 1920x1080 2ms VGA DVI-D HDMI LED Monitor
Quicklinx: 94SQWS00 Mfr#: VX2252MH
ViewSonic's VX2252MH is a 22" (21.5" viewable) Full HD, glossy-finish display that offers the ultimate visual experience for gaming and multimedia entertainment. The VX2252MH features ClearMotiv II technology that delivers 2 ms ultra-fast response time for blur-free images during extreme gaming, and an ultra-high 50M:1 MEGA dynamic contrast ratio for sharp, crisp color performance for enjoying movies. Integrated D-sub, DVI and HDMI inputs provide flexible connectivity for high-definition multimedia devices and gaming consoles, and dual built-in 2 W stereo speakers complete the package for multimedia enjoyment. With a VESA-mountable design, the VX2252MH offers flexible mounting options for any of your gaming and video entertainment needs.
ViewSonic VX2252MH - LED monitor - Full HD (1080p) - 22"
LED-backlit LCD monitor - 22"
Energy Class
Class A
Energy Consumption per Year
28 kWh
Power Consumption (On mode)
19 W
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 50000000:1 (dynamic)
Response Time
2 ms (gray-to-gray)
Input Connectors
HDMI, DVI-D, VGA
Speakers
Integrated
Display Position Adjustments
Tilt
Screen Coating
Anti-glare, 3H Hard Coating
51.114 cm x 22.252 cm x 40.216 cm
3.3 kg
Environmental Standards
ENERGY STAR Qualified
FCC Class B certified, UL, C-Tick, BSMI, cUL, ICES-003, NOM, SASO, TUV S, WHQL, CB, CCC, EMC, DOC, PSB, RoHS, WEEE, GOST-R, REACH, UkrSEPRO, ERP
(Austria, Germany, Switzerland - 2 years)
Display Type
Energy Class
Class A
28 kWh
19 W
Diagonal Size
22"
Viewable Size
21.5"
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
Response Time
2 ms (gray-to-gray)
Vertical Refresh Rate
50 - 75 Hz
Horizontal Refresh Rate
24 - 82 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
WLED
Controls & Adjustments
Brightness, contrast, colour balance, input select
HDCP, Eco-Mode, ClearMotiv II, game mode, Mega Dynamic Contrast Ratio, a-Si technology
51.114 cm x 22.252 cm x 40.216 cm - with stand
3.3 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
2 Watt
VGA , HDMI , DVI-D (HDCP) , Audio line-in , Headphones
Mechanical
Tilt
Tilt Angle
20
Flat Panel Mount Interface
100 x 100 mm
1 x VGA cable , 1 x DVI cable , 1 x audio cable
Power Supply
External
22 Watt
On / Off Switch
No
Included Software
ViewSonic Wizard
Dimensions & Weight Details
With stand - width: 51.114 cm - depth: 22.252 cm - height: 40.216 cm - weight: 3.3 kg , Without stand - width: 51.114 cm - depth: 5.272 cm - height: 32.724 cm - weight: 2.9 kg
ENERGY STAR Certified
10 - 90% (non-condensing)
