The ViewSonic VP2780-4K 27" Professional Ultra HD LED monitor delivers stunning definition for color-critical applications. With its high resolution, and SuperClear IPS technology for wide-angle viewing, this 10-bit monitor can display up to 1.07 billion colors. It provides superior color accuracy and performance for content creation, graphic design, print, and other professional applications. Equipped with an exclusive wide-range gamma setting and ViewMode technology, the VP2780-4K delivers optimized screen adjustments for different viewing scenarios. One of the first Ultra HD monitors to feature future-proof HDMI 2.0 to support 3840x2160 content at 60hz, along with DisplayPort 1.2a, dual MHL connectivity, and 4-port USB 3.0 for versatile connectivity to computing and entertainment devices. ViewSonic's MultiPicture functionality allows for efficient multitasking by providing simultaneous viewing of up to four split windows, while full ergonomic functionality delivers maximum comfort and enhanced productivity.
Stunning Ultra HD resolution
Displaying more than 8 million pixels with a high pixel density of 163 PPI, this Ultra HD 3840x2160 monitor delivers the ultimate in image detail and clarity for stunning, lifelike images. In addition, with 4x more pixels than Full HD resolution, this Ultra HD monitor displays more content to maximize productivity -
Incredible color accuracy
With impressive 10-bit color processing, this monitor can display up to 1.07 billion colors for professional-grade color accuracy and stunning images ideal for any multimedia application. Featuring Delta E=2 color accuracy, this monitor reproduces phenomenal colors nearly imperceptible from real life for consistent and brilliant colors, every time. -
Preset EBU and Gamma corrections
Delivering broadcast-like color and stable imaging, this Ultra HD monitor features a pro-style EBU preset ideal for video production and editing. Offering five gamma settings ranging from Gamma 1.8 to Gamma 2.6, this monitor optimizes color performance and contrast ratio for graphic design, video editing, photography production, and more. -
Rich connectivity capabilities
Future-proof HDMI 2.0 and DisplayPort 1.2a video standards support 3840x2160 resolution at a quick 60Hz frame rate - guaranteeing jitter-free multimedia, smooth screen performance, and true Ultra HD picture clarity. -
This monitor features MultiPicture support for multitasking and simultaneous viewing of up to 4 video sources at Full HD 1080p resolution. Picture-in-Picture (PIP) and Picture-by-Picture (PBP) functionality is also available for increased productivity. -
SuperColor IPS Panel technology
Enjoy accurate and vivid colors with consistent levels of brightness no matter your vantage point! With SuperClear IPS panel technology, this monitor delivers the same image quality whether you are looking at the screen from above, below, the front, or the side. -
Ergonomic design
With advanced ergonomic features, ViewSonic displays are designed to provide a greater range of adjustment for increased productivity and comfort. Users can reduce eyestrain and physical fatigue by adjusting the monitor via swivel, pivot, tilt, and height adjust options. -
ViewMode
ViewSonic's unique ViewMode feature offers "Game," "Movie," "Web," "Text," and "Mono" presets. These presets enhance gamma curve, color temperature, contrast, and brightness to deliver an optimized viewing experience for different screen applications. -
Enhanced viewing comfort
Flicker-Free technology and a blue light filter help to eliminate eye strain from extended viewing periods.
- ViewSonic VP2780-4K - LED monitor - 27"
- LED-backlit LCD monitor - 27"
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- Widescreen
- Native Resolution
- 4K 3840 x 2160 (DisplayPort: 60 Hz, HDMI: 60 Hz)
- Brightness
- 350 cd/m²
- Contrast Ratio
- 1000:1 / 20000000:1 (dynamic)
- Response Time
- 5 ms (grey-to-grey)
- Colour Support
- 1.07 billion colours
- Input Connectors
- HDMI, 2xMHL, DisplayPort, Mini DisplayPort
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare, 3H Hard Coating
- 64.27 cm x 34.78 cm x 46.97 cm
- 8.4 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified
- FCC Class B certified, UL, CB, RoHS, WEEE, TCO '06, REACH, ISO 9001:2008, ISO 14001:2004, TUV Nord, ERP, TCO Displays 6.0, CoC
- Display Type
- Diagonal Size
- 27"
- Built-in Devices
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- Widescreen
- Native Resolution
- Pixel Per Inch
- 163
- Brightness
- 350 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- Vertical Refresh Rate
- 24 - 120 Hz
- Horizontal Refresh Rate
- 15 - 204 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- WLED
- Controls & Adjustments
- Volume, brightness, contrast, colour balance, gamma correction, input select
- Sync on Green, SuperClear, Eco-Mode, Colour gamut EBU, Advanced Frame Rate Control (AFRC), MultiPicture
- 64.27 cm x 34.78 cm x 46.97 cm - with stand
- 8.4 kg
- HDMI , 2 x MHL / HDMI , DisplayPort , Mini DisplayPort , 4 x USB 3.0 downstream , USB 3.0 upstream (Type B) , Headphones
Mechanical
- Tilt Angle
- -5/+23
- Swivel Angle
- 120
- Rotation Angle
- 90
- Height Adjustment
- 150 mm
- Flat Panel Mount Interface
- 100 x 100 mm
- Cables Included
- 1 x DisplayPort cable , 1 x Mobile High-Definition Link (MHL) cable , 1 x HDMI cable , 1 x USB cable
- Backlight Life
- 30,000 hours
- Power Supply
- External
- Voltage Required
- AC 120/230 V (50 - 60 Hz)
- 49 Watt
- Included Software
- ViewSonic Wizard
- Dimensions & Weight Details
- Without stand - width: 64.27 cm - depth: 5.6 cm - height: 38.17 cm - weight: 5.4 kg , With stand - width: 64.27 cm - depth: 34.78 cm - height: 46.97 cm - weight: 8.4 kg
- 0 °C
- 40 °C
- 20 - 90% (non-condensing)
