ViewSonic VP2780-4K 27" 3840x2160 4K UHD HDMI MHL DisplayPort IPS LED Monitor
Quicklinx: BB2ZWS00 Mfr#: VP2780-4K
The ViewSonic VP2780-4K 27" Professional Ultra HD LED monitor delivers stunning definition for color-critical applications. With its high resolution, and SuperClear IPS technology for wide-angle viewing, this 10-bit monitor can display up to 1.07 billion colors. It provides superior color accuracy and performance for content creation, graphic design, print, and other professional applications. Equipped with an exclusive wide-range gamma setting and ViewMode technology, the VP2780-4K delivers optimized screen adjustments for different viewing scenarios. One of the first Ultra HD monitors to feature future-proof HDMI 2.0 to support 3840x2160 content at 60hz, along with DisplayPort 1.2a, dual MHL connectivity, and 4-port USB 3.0 for versatile connectivity to computing and entertainment devices. ViewSonic's MultiPicture functionality allows for efficient multitasking by providing simultaneous viewing of up to four split windows, while full ergonomic functionality delivers maximum comfort and enhanced productivity.
  • Stunning Ultra HD resolution
    Displaying more than 8 million pixels with a high pixel density of 163 PPI, this Ultra HD 3840x2160 monitor delivers the ultimate in image detail and clarity for stunning, lifelike images. In addition, with 4x more pixels than Full HD resolution, this Ultra HD monitor displays more content to maximize productivity
  • Incredible color accuracy
    With impressive 10-bit color processing, this monitor can display up to 1.07 billion colors for professional-grade color accuracy and stunning images ideal for any multimedia application. Featuring Delta E=2 color accuracy, this monitor reproduces phenomenal colors nearly imperceptible from real life for consistent and brilliant colors, every time.
  • Preset EBU and Gamma corrections
    Delivering broadcast-like color and stable imaging, this Ultra HD monitor features a pro-style EBU preset ideal for video production and editing. Offering five gamma settings ranging from Gamma 1.8 to Gamma 2.6, this monitor optimizes color performance and contrast ratio for graphic design, video editing, photography production, and more.
  • Rich connectivity capabilities
    Future-proof HDMI 2.0 and DisplayPort 1.2a video standards support 3840x2160 resolution at a quick 60Hz frame rate - guaranteeing jitter-free multimedia, smooth screen performance, and true Ultra HD picture clarity.
  • MultiPicture functionality
    This monitor features MultiPicture support for multitasking and simultaneous viewing of up to 4 video sources at Full HD 1080p resolution. Picture-in-Picture (PIP) and Picture-by-Picture (PBP) functionality is also available for increased productivity.
  • SuperColor IPS Panel technology
    Enjoy accurate and vivid colors with consistent levels of brightness no matter your vantage point! With SuperClear IPS panel technology, this monitor delivers the same image quality whether you are looking at the screen from above, below, the front, or the side.
  • Ergonomic design
    With advanced ergonomic features, ViewSonic displays are designed to provide a greater range of adjustment for increased productivity and comfort. Users can reduce eyestrain and physical fatigue by adjusting the monitor via swivel, pivot, tilt, and height adjust options.
  • ViewMode
    ViewSonic's unique ViewMode feature offers "Game," "Movie," "Web," "Text," and "Mono" presets. These presets enhance gamma curve, color temperature, contrast, and brightness to deliver an optimized viewing experience for different screen applications.
  • Enhanced viewing comfort
    Flicker-Free technology and a blue light filter help to eliminate eye strain from extended viewing periods.
ViewSonic VP2780-4K - LED monitor - 27"
LED-backlit LCD monitor - 27"
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
Widescreen
Native Resolution
4K 3840 x 2160 (DisplayPort: 60 Hz, HDMI: 60 Hz)
Brightness
350 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
1.07 billion colours
Input Connectors
HDMI, 2xMHL, DisplayPort, Mini DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
64.27 cm x 34.78 cm x 46.97 cm
8.4 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
FCC Class B certified, UL, CB, RoHS, WEEE, TCO '06, REACH, ISO 9001:2008, ISO 14001:2004, TUV Nord, ERP, TCO Displays 6.0, CoC
Display Type
Diagonal Size
27"
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
Widescreen
Native Resolution
Pixel Per Inch
163
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
24 - 120 Hz
Horizontal Refresh Rate
15 - 204 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
WLED
Controls & Adjustments
Volume, brightness, contrast, colour balance, gamma correction, input select
Sync on Green, SuperClear, Eco-Mode, Colour gamut EBU, Advanced Frame Rate Control (AFRC), MultiPicture
64.27 cm x 34.78 cm x 46.97 cm - with stand
8.4 kg
HDMI , 2 x MHL / HDMI , DisplayPort , Mini DisplayPort , 4 x USB 3.0 downstream , USB 3.0 upstream (Type B) , Headphones
Mechanical
Tilt Angle
-5/+23
Swivel Angle
120
Rotation Angle
90
Height Adjustment
150 mm
Flat Panel Mount Interface
100 x 100 mm
1 x DisplayPort cable , 1 x Mobile High-Definition Link (MHL) cable , 1 x HDMI cable , 1 x USB cable
Backlight Life
30,000 hours
Power Supply
External
AC 120/230 V (50 - 60 Hz)
49 Watt
Included Software
ViewSonic Wizard
Dimensions & Weight Details
Without stand - width: 64.27 cm - depth: 5.6 cm - height: 38.17 cm - weight: 5.4 kg , With stand - width: 64.27 cm - depth: 34.78 cm - height: 46.97 cm - weight: 8.4 kg
20 - 90% (non-condensing)
