ViewSonic VP2772 27" 2560x1440 6ms DVI-D HDMI DisplayPort LED Monitor
Quicklinx: 96LRWS00 Mfr#: VP2772
ViewSonic's VP2772 is a 27" ultra-high resolution display with 2560 x 1440 QHD resolution and 10-bit color. Covering 99% of the Adobe RGB color space, the VP2772 meets the high color standards of photographers, graphic designers, video editors, print departments, and other design professionals. With its advanced 12-bit color engine and 14-bit LUT, the VP2772 smoothly processes, grades, and renders 68.7 billion colors to create stunning images with rich depth and detail. Equipped with dual DisplayPort inputs and one DisplayPort output, it allows one image source to be shown simultaneously on multiple daisy-chained displays without any difference in color. In addition, HDMI and DVI inputs, and four USB 3.0 ports let users connect with multimedia and storage devices. The VP2772 is also ergonomically designed with tilt, pivot, swivel and height adjustments to create a more comfortable and efficient working environment. The ViewSonic VP2772 is the ultimate professional grade display for the most demanding color-critical applications.
  • See 99% of the Adobe RGB wide color gamut
    With the capability to accurately display 99% of the rich, true colors of the wider Adobe RGB color space, the VP2772 displays graphic design work with the fullest color and details. Original high-resolution images are depicted as accurately as possible - in the high-definition format in which they were saved. The VP2772 is extremely well-suited to photography, graphic design work, publishing, media creation, CAD/CAM drawing, and more.
  • 12-bit color engine and 14-bit LUT reproduces 68.7 billion true-to-life colors
    The VP2772 utilizes a 12-bit color engine with a 14-bit LUT to handle image color rendering and HD content. The 12-bit color engine processes and displays 12-bit input signals, up to 68.7 billion colors, without reducing the signal quality while ensuring true-to-life images. In addition, the 14-bit LUT provides smoother color gradations.
  • Stunning color clarity
    ViewSonic's high-performance LED monitor offers 2560 x 1440 native ultra-high resolution, quadrupling the resolution of 720p.
  • High-definition daisy chain capability
    Equipped with 2 DisplayPort inputs and 1 DisplayPort output, the VP2772 supports daisy-chaining of multiple displays for multi-screen setup and easy cable management. Even with multiple displays daisy-chained to the VP2772, high-definition content and color remains consistent across screens. Quad HD is supported on two daisy-chained displays, while Full HD is supported on four daisy-chained displays.
  • Flexible connectivity options
    The VP2772 provides flexible connectivity with HDMI and DVI inputs, which allow users to connect and toggle between different sources. An integrated 4-port USB 3.0 hub supports versatile connection to peripherals.
  • SuperClear IPS panel with wide viewing angles
    Get the best view, wherever you are. SuperClear IPS technology delivers 178-degree of vertical and horizontal viewing angles. Experience accurate, vivid colors, and consistent brightness levels whether you're looking at the screen from above, below, the front, or the side - with no distortion or decay.
  • Ergonomic design made for comfort and productivity
    Transform your working environment! ViewSonic's high-performance LED monitor is ergonomically designed to offer users the flexibility they need to increase their productivity and comfort. Design features include 120° swivel, 90° pivot, 0-5.9" (0-150 mm) height, and -5° to 23° tilt adjustments, allowing the screen a greater range of movement.
ViewSonic VP2772 - LED monitor - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class C
Energy Consumption per Year
85.1 kWh
Power Consumption (On mode)
58.3 W
Built-in Devices
USB Hub
Panel Type
IPS
Aspect Ratio
Widescreen - 16:9
Native Resolution
QHD 2560 x 1440
Brightness
350 cd/m2
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
6 ms
Input Connectors
HDMI, DVI-D, 2xDisplayPort
Display Position Adjustments
Height adjustable, pivot (rotation), swivel, tilt
Screen Coating
Anti-glare, 3H Hard Coating
64.26 cm x 34.8 cm x 46.48 cm - with stand
8.5 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
FCC Class B certified, UL, C-Tick, BSMI, cUL, ICES-003, NOM, TUV S, CB, CCC, PSB, RoHS, WEEE, GOST-R, REACH, UkrSEPRO, ERP, CECP, CEL, TCO Displays 6.0
3 years warranty
Display Type
Energy Class
Class C
85.1 kWh
58.3 W
Diagonal Size
27"
Built-in Devices
USB Hub
Panel Type
IPS
Aspect Ratio
Widescreen - 16:9
Native Resolution
QHD 2560 x 1440
Brightness
350 cd/m2
Contrast Ratio
Response Time
6 ms
Vertical Refresh Rate
50 - 75 Hz
Horizontal Refresh Rate
24 - 92 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
WLED
Controls & Adjustments
Brightness, contrast, colour balance, input select
HDCP, SuperClear, Eco-Mode, 14-bit gamma, 99% Adobe RGB colour gamut
8.5 kg
HDMI ( HDCP ) , DVI-D (dual link) ( HDCP ) , DisplayPort , Mini DisplayPort , 4 x USB 3.0 downstream , USB 3.0 upstream , Audio line-in , Headphones , DisplayPort output
Mechanical
Tilt Angle
-5/+23
Swivel Angle
120
Rotation Angle
90
Height Adjustment
150 mm
Flat Panel Mount Interface
100 x 100 mm
1 x DisplayPort cable , 1 x HDMI cable , 1 x DVI cable , 1 x SuperSpeed USB cable
Backlight Life
30,000 hours
Power Supply
External
AC 120/230 V ( 50 - 60 Hz )
65 Watt
On / Off Switch
No
Included Software
ViewSonic Wizard
Dimensions & Weight Details
Without stand - width: 64.26 cm - depth: 5.6 cm - height: 38.1 cm - weight: 5.5 kg , With stand - width: 64.26 cm - depth: 34.8 cm - height: 46.48 cm - weight: 8.5 kg
3 years warranty
Service & Support Details
Limited warranty - parts and labour - 3 years , Limited warranty - backlight - 3 years
20 - 90% (non-condensing)
