The ViewSonic VP2770-LED 27" wide super IPS LED monitor, with 2560 x 1440 resolutions provides stunning high definition details with nearly 80% more pixels than a standard 1080p display. With support for 1.07 billion colors, a high 20000000:1 MEGA dynamic contrast ratio, and super wide 178/178 degree viewing angles, the VP2770-LED is the ultimate professional grade LCD monitor for design, digital photography, video production, architecture or any other application where true color and total screen viewing is essential. Flexible connectivity options include DisplayPort, HDMI, dual-link DVI and VGA, along with 4 USB ports for connecting your peripherals. The ergonomic stand provides height adjust, swivel, tilt and pivot for maximum comfort.
- ViewSonic VP2770-LED - LED monitor - 27"
- LED-backlit LCD monitor - 27"
- Energy Class
- Class B
- Energy Consumption per Year
- 51.2 kWh
- Power Consumption (On mode)
- 35.5 W
- Built-in Devices
- USB Hub
- Panel Type
- IPS
- Aspect Ratio
- Widescreen - 16:9
- Native Resolution
- Full HD 2560 x 1440
- Brightness
- 300 cd/m2
- Contrast Ratio
- 1000:1 / 20000000:1 (dynamic)
- Response Time
- 12 ms
- Input Connectors
- HDMI, DVI-D, VGA, DisplayPort
- Height adjustable, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare, 3H Hard Coating
- Black
- 64.26 cm x 34.8 cm x 46.48 cm - with stand
- 8.5 kg
- Environmental Standards
- ENERGY STAR Qualified , EPEAT Gold
- FCC Class B certified, UL, C-Tick, BSMI, cUL, ICES-003, SASO, CB, CCC, PSB, RoHS, WEEE, GOST-R, E-Standby, UkrSEPRO, KC, ERP
- 3 years warranty
- Display Type
- Energy Class
- Class B
- 51.2 kWh
- 35.5 W
- Diagonal Size
- 27"
- Viewable Size
- 27"
- Built-in Devices
- USB Hub
- Panel Type
- IPS
- Aspect Ratio
- Widescreen - 16:9
- Native Resolution
- Brightness
- 300 cd/m2
- Contrast Ratio
- Response Time
- 12 ms
- Vertical Refresh Rate
- 50 - 75 Hz
- Horizontal Refresh Rate
- 24 - 92 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- WLED
- Controls & Adjustments
- Brightness, contrast, H/V position, sharpness, colour balance, input select, colour temperature, H-size, aspect control
- sRGB colour management, HDCP, Eco-Mode, Mega Dynamic Contrast Ratio
- Black
- 8.5 kg
- VGA , DVI-D , DisplayPort , HDMI , USB upstream ( Type B ) , 2 x USB 2.0 downstream , 2 x USB 3.0 downstream , Headphones
Mechanical
- Height, pivot (rotation), swivel, tilt
- Tilt Angle
- -5/+20
- Swivel Angle
- 120
- Rotation Angle
- 90
- Height Adjustment
- 150 mm
- Cables Included
- 1 x DVI cable , 1 x VGA cable , 1 x DisplayPort cable , 1 x SuperSpeed USB cable
- Backlight Life
- 30,000 hours
- Power Supply
- Internal
- Voltage Required
- AC 120/230 V ( 50 - 60 Hz )
- 40 Watt
- On / Off Switch
- No
- Included Software
- ViewSonic Wizard
- Dimensions & Weight Details
- Without stand - width: 64.26 cm - depth: 5.6 cm - height: 38.1 cm - weight: 5.8 kg , With stand - width: 64.26 cm - depth: 34.8 cm - height: 46.48 cm - weight: 8.5 kg
- EPEAT Compliant
- EPEAT Gold
- 3 years warranty
- Service & Support Details
- Limited warranty - parts and labour - 3 years , Limited warranty - backlight - 3 years
- 0 °C
- 40 °C
- 20 - 90% (non-condensing)
