ViewSonic VP2770-LED 27" 2560 x 1440 12ms HDMI DVI-D VGA DP Black Monitor
Quicklinx: 89XNWS00 Mfr#: VP2770-LED
The ViewSonic VP2770-LED 27" wide super IPS LED monitor, with 2560 x 1440 resolutions provides stunning high definition details with nearly 80% more pixels than a standard 1080p display. With support for 1.07 billion colors, a high 20000000:1 MEGA dynamic contrast ratio, and super wide 178/178 degree viewing angles, the VP2770-LED is the ultimate professional grade LCD monitor for design, digital photography, video production, architecture or any other application where true color and total screen viewing is essential. Flexible connectivity options include DisplayPort, HDMI, dual-link DVI and VGA, along with 4 USB ports for connecting your peripherals. The ergonomic stand provides height adjust, swivel, tilt and pivot for maximum comfort.
ViewSonic VP2770-LED - LED monitor - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class B
Energy Consumption per Year
51.2 kWh
Power Consumption (On mode)
35.5 W
Built-in Devices
USB Hub
Panel Type
IPS
Aspect Ratio
Widescreen - 16:9
Native Resolution
Full HD 2560 x 1440
Brightness
300 cd/m2
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
12 ms
Input Connectors
HDMI, DVI-D, VGA, DisplayPort
Display Position Adjustments
Height adjustable, pivot (rotation), swivel, tilt
Screen Coating
Anti-glare, 3H Hard Coating
64.26 cm x 34.8 cm x 46.48 cm - with stand
8.5 kg
Environmental Standards
ENERGY STAR Qualified , EPEAT Gold
FCC Class B certified, UL, C-Tick, BSMI, cUL, ICES-003, SASO, CB, CCC, PSB, RoHS, WEEE, GOST-R, E-Standby, UkrSEPRO, KC, ERP
3 years warranty
Display Type
Energy Class
Class B
51.2 kWh
35.5 W
Diagonal Size
27"
Viewable Size
27"
Built-in Devices
USB Hub
Panel Type
IPS
Aspect Ratio
Widescreen - 16:9
Native Resolution
Full HD 2560 x 1440
Brightness
300 cd/m2
Contrast Ratio
Response Time
12 ms
Vertical Refresh Rate
50 - 75 Hz
Horizontal Refresh Rate
24 - 92 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
WLED
Controls & Adjustments
Brightness, contrast, H/V position, sharpness, colour balance, input select, colour temperature, H-size, aspect control
sRGB colour management, HDCP, Eco-Mode, Mega Dynamic Contrast Ratio
8.5 kg
VGA , DVI-D , DisplayPort , HDMI , USB upstream ( Type B ) , 2 x USB 2.0 downstream , 2 x USB 3.0 downstream , Headphones
Mechanical
Tilt Angle
-5/+20
Swivel Angle
120
Rotation Angle
90
Height Adjustment
150 mm
1 x DVI cable , 1 x VGA cable , 1 x DisplayPort cable , 1 x SuperSpeed USB cable
Backlight Life
30,000 hours
Power Supply
Internal
AC 120/230 V ( 50 - 60 Hz )
40 Watt
On / Off Switch
No
Included Software
ViewSonic Wizard
Dimensions & Weight Details
Without stand - width: 64.26 cm - depth: 5.6 cm - height: 38.1 cm - weight: 5.8 kg , With stand - width: 64.26 cm - depth: 34.8 cm - height: 46.48 cm - weight: 8.5 kg
EPEAT Compliant
EPEAT Gold
3 years warranty
Service & Support Details
Limited warranty - parts and labour - 3 years , Limited warranty - backlight - 3 years
20 - 90% (non-condensing)
