ViewSonic VG2860mhl-4k 28" 2ms DVI DP HDMI 4K Monitor
Quicklinx: BD3KWS00 Mfr#: VG2860mhl-4k
If you're writing thousands of lines of code, making financial forecasts, or viewing video surveillance footage, the efficiency of your work often comes down to the details on your monitor. With stunning 3840x2160 resolution at a high refresh rate of 60Hz, this 28" monitor is engineered to deliver the ultimate in detail and clarity so that the finer points never go by unnoticed. When multiple projects need your attention, ViewSonic's exclusive MultiPicture functionality lets you view up to four Full HD video sources at once, while a fully adjustable ergonomic stand keeps you comfortable. The ViewSonic VG2860mhl-4K monitor delivers the screen size, incredible detail, and multitasking features you need to get your job done.
  • Multipicture functionality
    This monitor features MultiPicture support for multi-tasking and simultaneous viewing of up to 4 video sources at Full HD 1080p resolution. Picture-in-Picture (PIP) and Picture-by-Picture (PBP) functionality is also available for increased productivity.
  • Stunning Ultra HD resolution
    Displaying more than 8 million pixels with a high pixel density of 163 PPI, this Ultra HD monitor delivers the ultimate in image detail and clarity for stunning, lifelike images. In addition, with 4x more pixels than Full HD resolution, this Ultra HD monitor displays more content to maximize productivity.
  • Next generation connectivity
    Future-proof DisplayPort 1.2a and Mini DisplayPort 1.2a video standards support 3840x2160 resolution at a quick 60Hz frame rate - guaranteeing jitter-free multimedia, smooth screen performance, and true Ultra HD picture clarity.
  • Ergonomic design
    With advanced ergonomic features, ViewSonic monitors are designed to provide a greater range of adjustment for increased productivity and comfort. Users can reduce eyestrain and physical fatigue by adjusting the monitor via swivel, pivot, tilt, and height adjust possibilities.
  • Ultra-fast response time
    With an ultra-fast response time, this monitor delivers smooth images without streaking, blurring or ghosting. Experience digital broadcast quality, full-motion video with razor-sharp images that never blur.
  • Optimized view settings
    ViewSonic's unique ViewMode feature offers "Game," "Movie," "Web," "Text," and "Mono" presets. These presets enhance gamma curve, color temperature, contrast, and brightness to deliver an optimized viewing experience for different screen applications.
  • Enhanced viewing comfort
    With Flicker-Free technology and a Blue Light Filter, this monitor helps to eliminate eyestrain that comes with extended viewing periods - meaning you can outlast and outgame your opponents just as their eyes begin fail them.
  • Dual integrated speakers
    Designed with dual integrated speakers, this display combines incredible screen performance with stereo sound.
ViewSonic Ergonomic VG2860MHL-4K - LED monitor - 28"
LED-backlit LCD monitor - 28"
Stereo speakers, USB 3.0 hub
Aspect Ratio
16:9
Native Resolution
4K UHD (2160p) 3840 x 2160 (DisplayPort: 60 Hz, HDMI: 30 Hz, DVI: 30 Hz)
Brightness
300 cd/m²
Contrast Ratio
1000:1
Response Time
2 ms (gray-to-gray)
Colour Support
1.07 billion colours
Input Connectors
HDMI, DVI-D, DisplayPort
Speakers
Integrated
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
65.97 cm x 26.6 cm x 48.34 cm
7.8 kg
Microsoft Certification
Compatible with Windows 7
FCC Class B certified, WHQL, CB, RoHS, WEEE, cULus, REACH, ERP
3-year warranty
Display Type
Diagonal Size
28"
Built-in Devices
Aspect Ratio
16:9
Native Resolution
Brightness
300 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
2 ms (gray-to-gray)
Vertical Refresh Rate
24 - 75 Hz
Horizontal Refresh Rate
24 - 160 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Screen Coating
Backlight Technology
WLED
Controls & Adjustments
Brightness, contrast, colour balance, input select
Eco-Mode, Flicker Free technology, a-Si technology, Blue Light Filter technology
65.97 cm x 26.6 cm x 48.34 cm - with stand
7.8 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
3 Watt
HDMI , 2 x DisplayPort , DVI-D , 2 x USB 2.0 downstream , 2 x USB 3.0 downstream , USB 3.0 upstream (Type B) , Audio line-in , Headphones
Mechanical
Tilt Angle
-5/+37
Swivel Angle
350
Rotation Angle
90
Height Adjustment
150 mm
VESA Mounting Interface
100 x 100 mm
Stand
1 x DisplayPort cable , 1 x Mobile High-Definition Link (MHL) cable , 1 x audio cable , 1 x USB cable
Backlight Life
30,000 hours
Security Slot Type
Kensington security slot
Input Voltage
Power Consumption (Typical)
48 Watt
Included Software
ViewSonic Wizard
Dimensions & Weight Details
With stand - width: 65.97 cm - depth: 26.6 cm - height: 48.34 cm - weight: 7.8 kg , Without stand - width: 65.97 cm - depth: 4.93 cm - height: 39.1 cm - weight: 5.3 kg
Limited warranty - parts and labour - 3 years , Limited warranty - backlight - 3 years
10 - 90% (non-condensing)
