If you're writing thousands of lines of code, making financial forecasts, or viewing video surveillance footage, the efficiency of your work often comes down to the details on your monitor. With stunning 3840x2160 resolution at a high refresh rate of 60Hz, this 28" monitor is engineered to deliver the ultimate in detail and clarity so that the finer points never go by unnoticed. When multiple projects need your attention, ViewSonic's exclusive MultiPicture functionality lets you view up to four Full HD video sources at once, while a fully adjustable ergonomic stand keeps you comfortable. The ViewSonic VG2860mhl-4K monitor delivers the screen size, incredible detail, and multitasking features you need to get your job done.
Multipicture functionality
This monitor features MultiPicture support for multi-tasking and simultaneous viewing of up to 4 video sources at Full HD 1080p resolution. Picture-in-Picture (PIP) and Picture-by-Picture (PBP) functionality is also available for increased productivity. -
Stunning Ultra HD resolution
Displaying more than 8 million pixels with a high pixel density of 163 PPI, this Ultra HD monitor delivers the ultimate in image detail and clarity for stunning, lifelike images. In addition, with 4x more pixels than Full HD resolution, this Ultra HD monitor displays more content to maximize productivity. -
Next generation connectivity
Future-proof DisplayPort 1.2a and Mini DisplayPort 1.2a video standards support 3840x2160 resolution at a quick 60Hz frame rate - guaranteeing jitter-free multimedia, smooth screen performance, and true Ultra HD picture clarity. -
Ergonomic design
With advanced ergonomic features, ViewSonic monitors are designed to provide a greater range of adjustment for increased productivity and comfort. Users can reduce eyestrain and physical fatigue by adjusting the monitor via swivel, pivot, tilt, and height adjust possibilities. -
Ultra-fast response time
With an ultra-fast response time, this monitor delivers smooth images without streaking, blurring or ghosting. Experience digital broadcast quality, full-motion video with razor-sharp images that never blur. -
Optimized view settings
ViewSonic's unique ViewMode feature offers "Game," "Movie," "Web," "Text," and "Mono" presets. These presets enhance gamma curve, color temperature, contrast, and brightness to deliver an optimized viewing experience for different screen applications. -
Enhanced viewing comfort
With Flicker-Free technology and a Blue Light Filter, this monitor helps to eliminate eyestrain that comes with extended viewing periods - meaning you can outlast and outgame your opponents just as their eyes begin fail them. -
Dual integrated speakers
Designed with dual integrated speakers, this display combines incredible screen performance with stereo sound.
- ViewSonic Ergonomic VG2860MHL-4K - LED monitor - 28"
- LED-backlit LCD monitor - 28"
- Stereo speakers, USB 3.0 hub
- Aspect Ratio
- 16:9
- Native Resolution
- 4K UHD (2160p) 3840 x 2160 (DisplayPort: 60 Hz, HDMI: 30 Hz, DVI: 30 Hz)
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 2 ms (gray-to-gray)
- Colour Support
- 1.07 billion colours
- Input Connectors
- HDMI, DVI-D, DisplayPort
- Speakers
- Integrated
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare, 3H Hard Coating
- Voltage
- AC 120/230 V (50/60 Hz)
- 65.97 cm x 26.6 cm x 48.34 cm
- 7.8 kg
- Microsoft Certification
- Compatible with Windows 7
- FCC Class B certified, WHQL, CB, RoHS, WEEE, cULus, REACH, ERP
- 3-year warranty
- Display Type
- Diagonal Size
- 28"
- Built-in Devices
- Aspect Ratio
- 16:9
- Native Resolution
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Response Time
- Vertical Refresh Rate
- 24 - 75 Hz
- Horizontal Refresh Rate
- 24 - 160 kHz
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Screen Coating
- Backlight Technology
- WLED
- Controls & Adjustments
- Brightness, contrast, colour balance, input select
- Eco-Mode, Flicker Free technology, a-Si technology, Blue Light Filter technology
- 65.97 cm x 26.6 cm x 48.34 cm - with stand
- 7.8 kg
Audio
- Speakers - stereo - integrated
- Output Power / Channel
- 3 Watt
- HDMI , 2 x DisplayPort , DVI-D , 2 x USB 2.0 downstream , 2 x USB 3.0 downstream , USB 3.0 upstream (Type B) , Audio line-in , Headphones
Mechanical
- Tilt Angle
- -5/+37
- Swivel Angle
- 350
- Rotation Angle
- 90
- Height Adjustment
- 150 mm
- VESA Mounting Interface
- 100 x 100 mm
- Included Accessories
- Stand
- Cables Included
- 1 x DisplayPort cable , 1 x Mobile High-Definition Link (MHL) cable , 1 x audio cable , 1 x USB cable
- Backlight Life
- 30,000 hours
- Security Slot Type
- Kensington security slot
- Input Voltage
- Power Consumption (Typical)
- 48 Watt
- Included Software
- ViewSonic Wizard
- Dimensions & Weight Details
- With stand - width: 65.97 cm - depth: 26.6 cm - height: 48.34 cm - weight: 7.8 kg , Without stand - width: 65.97 cm - depth: 4.93 cm - height: 39.1 cm - weight: 5.3 kg
- Limited warranty - parts and labour - 3 years , Limited warranty - backlight - 3 years
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
