Product
ViewSonic VG2753 27" 1920 x 1080 5ms VGA HDMI DP USB LCD Monitor
Quicklinx: CQBKWS00 Mfr#: VG2753
Diagonal Size: 27in
Max Resolution: 1920 x 1080
Response Time: 5ms
Speakers: Speaker(s)
Interfaces: DisplayPort, HDMI, Mini DisplayPort, VGA (HD-15)
£227.31 ex VAT
£272.77 inc VAT
With future-proof connectivity and advanced ergonomics, the ViewSonic VG2753 is a productivity-boosting monitor perfect for corporate, government, and education environments. Designed with SuperClear IPS panel technology for wide-angle viewing and incredibly vivid colors, this monitor also features a 3-sided thin-bezel design for a seamless viewing experience in multi-monitor setups. For maximum comfort and a customized fit, a robust fully ergonomic stand gives you tilt, pivot, swivel, and height-adjustable options. In addition, VDI client endpoints can be easily attached to the stand’s integrated client mount, saving desktop space and minimizing cable clutter without interfering with ergonomic functionality. Extensive connectivity options include VGA, HDMI, DisplayPort, and Mini DisplayPort so that you can connect to a variety of HD and analog devices – today and tomorrow.
ViewSonic VG2753 - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class A
Energy Consumption per Year
35 kWh
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Input Connectors
HDMI, VGA, DisplayPort, Mini DisplayPort
Display Position Adjustments
62.23 cm x 23.37 cm x 54.36 cm
6.4 kg
Europe
Environmental Standards
ENERGY STAR Qualified
FCC Class B certified, GS, ICES-003, CB, DOC, RoHS, WEEE, cULus, ERP, RoHS2, EAC, TCO Displays 7.0, CE/EMC, REACH SvHC
(Austria, Germany, Switzerland - 3 years)
Display Type
Energy Class
Class A
35 kWh
Diagonal Size
27"
Viewable Size
27"
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
48 - 76 Hz
Horizontal Refresh Rate
31 - 86 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Sync on Green, SuperClear, frameless bezel design, Composite Sync, ViewMode
62.23 cm x 23.37 cm x 54.36 cm - with stand
6.4 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
VGA , HDMI , DisplayPort , Microphone , Headphones , 2 x USB 3.0 downstream , USB 3.0 upstream , Mini DisplayPort
Mechanical
Tilt Angle
-5/+20
Swivel Angle
360
Rotation Angle
90
Height Adjustment
130 mm
Flat Panel Mount Interface
100 x 100 mm
Integrated cable management
1 x Mini DisplayPort-DisplayPort cable - miniDisplayPort to DisplayPort , 1 x USB cable
Europe
27 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.3 Watt
Dimensions & Weight Details
Without stand - width: 62.23 cm - depth: 5.33 cm - height: 37.08 cm - weight: 4.31 kg , With stand - width: 62.23 cm - depth: 23.37 cm - height: 54.36 cm - weight: 6.4 kg
ENERGY STAR Certified
20 - 90% (non-condensing)
ViewSonic VG2753 27 Bundle deal on ViewSonic VG2753 27" 1920 x 1080 5ms VGA HDMI DP USB LCD Monitor
Including:
Microsoft Office 365 Business Premium Retail 1 Year Microsoft Office 365 Business Premium Retail 1 Year worth £99.76 | in stock
£327.07
Diagonal Size: 27in
Response Time: 5ms
Interfaces: HDMI
Interfaces: Mini DisplayPort
Interfaces: VGA (HD-15)
Brand: ViewSonic
Price Range Ex VAT: 150 - 300
