The ViewSonic VG2439Smh is a 24" (23.6" viewable) Full HD LED multimedia monitor with future-proof connectivity and full ergonomic functionality ideal for corporate, government and education. With SuperClear MVA panel technology for wide-angle viewing, and 20M: 1 dynamic contrast ratio, this monitor delivers incredibly sharp images and video playback. Integrated with HDMI, DisplayPort, VGA and 2 USB ports, the VG2439Smh allows flexible connection to PC systems, laptops and other multimedia peripheral devices. ViewSonic's exclusive ViewMode provides intuitive presets to deliver optimized screen performance in different applications. In addition, Flicker-Free and Blue Light Filter technology help to eliminate eye strain from extended viewing periods. The LED backlight design makes this display Energy Star.
Enjoy accurate and vivid colors with consistent levels of brightness no matter the vantage point. With SuperClear MVA panel technology, this monitor delivers the same image quality whether you are looking at the screen from above, below, the front, or the side. -
High-performance DisplayPort
Future-proof DisplayPort connectivity delivers excellent refresh rate, high resolution, and incredibly rich color and sound. -
The power of HDMI
HDMI is a future-proof video standard that delivers true digital picture and audio clarity. The HDMI interface on this monitor allows you to connect to a variety of HD devices including gaming consoles, Blu-ray players, laptop PCs, digital cameras, and many others for the ultimate true high-definition experience. -
Full HD 1080p resolution
This monitor features Full HD 1920x1080 resolution for unbelievable pixel-by-pixel image performance. You'll experience amazing clarity and detail whether it be while working, gaming, or enjoying the latest in multimedia entertainment. -
Optimized view settings
ViewSonic's unique ViewMode feature offers "Game," "Movie," "Web," "Text," and "Mono" presets. These presets enhance gamma curve, color temperature, contrast, and brightness to deliver an optimized viewing experience for different screen applications. -
Vesa-compatible mount design
Mount the monitor as you see fit using its convenient VESA-compatible mount design. -
Dual integrated speakers
Designed with dual integrated speakers, this display combines incredible screen performance with stereo sound for an immersive multimedia experience. -
Enhanced viewing comfort
With Flicker-Free technology and a Blue Light Filter, this monitor helps to eliminate eyestrain that comes with extended viewing periods - meaning you can outlast and outgame your opponents just as their eyes begin fail them.
- ViewSonic Ergonomic VG2439SMH - LED monitor - Full HD (1080p) - 24"
- LED-backlit LCD monitor - 24"
- Energy Class
- Class F
- USB 2.0 hub
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Brightness
- 250 cd/m²
- Contrast Ratio
- 3000:1 / 20000000:1 (dynamic)
- Response Time
- 5 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, VGA, DisplayPort
- Speakers
- Integrated
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare, 3H Hard Coating
- Voltage
- AC 120/230 V (50/60 Hz)
- 56.03 cm x 23.96 cm x 43.52 cm
- 5.2 kg
- Environmental Standards
- ENERGY STAR Qualified
- FCC Class B certified, UL, cUL, WHQL, CB, RoHS, WEEE, TUV Nord
- 3-year warranty
- Display Type
- Energy Class
- Class F
- Diagonal Size
- 24"
- Viewable Size
- 23.6"
- Built-in Devices
- USB 2.0 hub
- Aspect Ratio
- 16:9
- Native Resolution
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- Vertical Refresh Rate
- 50 - 75 Hz
- Horizontal Refresh Rate
- 24 - 82 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- WLED
- Controls & Adjustments
- Brightness, contrast, colour balance, input select
- Eco-Mode, Blue Light Filter technology
- 56.03 cm x 23.96 cm x 43.52 cm - with stand
- 5.2 kg
Audio
- Speakers - stereo - integrated
- Output Power / Channel
- 2 Watt
- VGA , HDMI , DisplayPort , 2 x USB 2.0 downstream , USB 2.0 upstream (Type B) , Audio line-in , Headphones
Mechanical
- Tilt Angle
- -5/+20
- Swivel Angle
- 360
- Rotation Angle
- 90
- Height Adjustment
- 135 mm
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), Flicker-free technology
- Included Accessories
- Stand
- Cables Included
- 1 x VGA cable , 1 x DisplayPort cable , 1 x audio cable , 1 x USB cable
- Backlight Life
- 30,000 hours
- Security Slot Type
- Kensington security slot
- Power Supply
- Internal
- Input Voltage
- Power Consumption SDR (On mode)
- 22 kWh/1000h
- Included Software
- ViewSonic Wizard
- Dimensions & Weight Details
- Without stand - width: 56.03 cm - depth: 5.82 cm - height: 33.17 cm - weight: 3.7 kg , With stand - width: 56.03 cm - depth: 23.96 cm - height: 43.52 cm - weight: 5.2 kg
Sustainability Information
- ENERGY STAR Certified
- ENERGY STAR Version
- 7.0
- Limited warranty - parts and labour - 3 years , Limited warranty - backlight - 3 years
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
