ViewSonic VG2439SMH 23.6" 1920x1080 5ms VGA DVI DP USB LED Monitor
Quicklinx: BNCSWS00 Mfr#: VG2439SMH
The ViewSonic VG2439Smh is a 24" (23.6" viewable) Full HD LED multimedia monitor with future-proof connectivity and full ergonomic functionality ideal for corporate, government and education. With SuperClear MVA panel technology for wide-angle viewing, and 20M: 1 dynamic contrast ratio, this monitor delivers incredibly sharp images and video playback. Integrated with HDMI, DisplayPort, VGA and 2 USB ports, the VG2439Smh allows flexible connection to PC systems, laptops and other multimedia peripheral devices. ViewSonic's exclusive ViewMode provides intuitive presets to deliver optimized screen performance in different applications. In addition, Flicker-Free and Blue Light Filter technology help to eliminate eye strain from extended viewing periods. The LED backlight design makes this display Energy Star.
  • SuperClear MVA panel technology
    Enjoy accurate and vivid colors with consistent levels of brightness no matter the vantage point. With SuperClear MVA panel technology, this monitor delivers the same image quality whether you are looking at the screen from above, below, the front, or the side.
  • High-performance DisplayPort
    Future-proof DisplayPort connectivity delivers excellent refresh rate, high resolution, and incredibly rich color and sound.
  • The power of HDMI
    HDMI is a future-proof video standard that delivers true digital picture and audio clarity. The HDMI interface on this monitor allows you to connect to a variety of HD devices including gaming consoles, Blu-ray players, laptop PCs, digital cameras, and many others for the ultimate true high-definition experience.
  • Full HD 1080p resolution
    This monitor features Full HD 1920x1080 resolution for unbelievable pixel-by-pixel image performance. You'll experience amazing clarity and detail whether it be while working, gaming, or enjoying the latest in multimedia entertainment.
  • Optimized view settings
    ViewSonic's unique ViewMode feature offers "Game," "Movie," "Web," "Text," and "Mono" presets. These presets enhance gamma curve, color temperature, contrast, and brightness to deliver an optimized viewing experience for different screen applications.
  • Vesa-compatible mount design
    Mount the monitor as you see fit using its convenient VESA-compatible mount design.
  • Dual integrated speakers
    Designed with dual integrated speakers, this display combines incredible screen performance with stereo sound for an immersive multimedia experience.
  • Enhanced viewing comfort
    With Flicker-Free technology and a Blue Light Filter, this monitor helps to eliminate eyestrain that comes with extended viewing periods - meaning you can outlast and outgame your opponents just as their eyes begin fail them.
ViewSonic Ergonomic VG2439SMH - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class F
USB 2.0 hub
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Brightness
250 cd/m²
Contrast Ratio
3000:1 / 20000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA, DisplayPort
Speakers
Integrated
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
56.03 cm x 23.96 cm x 43.52 cm
5.2 kg
Environmental Standards
ENERGY STAR Qualified
FCC Class B certified, UL, cUL, WHQL, CB, RoHS, WEEE, TUV Nord
3-year warranty
Display Type
Energy Class
Class F
Diagonal Size
24"
Viewable Size
23.6"
Built-in Devices
USB 2.0 hub
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
50 - 75 Hz
Horizontal Refresh Rate
24 - 82 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
WLED
Controls & Adjustments
Brightness, contrast, colour balance, input select
Eco-Mode, Blue Light Filter technology
56.03 cm x 23.96 cm x 43.52 cm - with stand
5.2 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
2 Watt
VGA , HDMI , DisplayPort , 2 x USB 2.0 downstream , USB 2.0 upstream (Type B) , Audio line-in , Headphones
Mechanical
Tilt Angle
-5/+20
Swivel Angle
360
Rotation Angle
90
Height Adjustment
135 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), Flicker-free technology
Stand
1 x VGA cable , 1 x DisplayPort cable , 1 x audio cable , 1 x USB cable
Backlight Life
30,000 hours
Security Slot Type
Kensington security slot
Power Supply
Internal
Input Voltage
22 kWh/1000h
Included Software
ViewSonic Wizard
Dimensions & Weight Details
Without stand - width: 56.03 cm - depth: 5.82 cm - height: 33.17 cm - weight: 3.7 kg , With stand - width: 56.03 cm - depth: 23.96 cm - height: 43.52 cm - weight: 5.2 kg
Sustainability Information
ENERGY STAR Certified
ENERGY STAR Version
7.0
Limited warranty - parts and labour - 3 years , Limited warranty - backlight - 3 years
10 - 90% (non-condensing)
BNCS StarTech.com Articulating Monitor Arm In Stock £132.69
BNCS StarTech.com Dual Monitor Stand In Stock £91.00
BNCS StarTech.com TV/Monitor Arm - Wallmount In Stock £82.52
BNCS StarTech.com Monitor Arm - Heavy Duty In Stock £93.49
