ViewSonic VG2437SMC 23.6" VGA DVI DP USB LED Monitor with Integrated Webcam
Quicklinx: B8JNWS00 Mfr#: VG2437smc
Diagonal Size: 24in
Max Resolution: 1920 x 1080
Response Time: 6.9ms
Speakers: Speaker(s)
Interfaces: DisplayPort, DVI, VGA (HD-15)
£172.44 ex VAT
£206.92 inc VAT
The ViewSonic VG2437Smc is a 24" (23.6" viewable) Full HD ergonomic monitor with an integrated 2-megapixel webcam, dual speakers, and mic/headphone ports for video conferencing. With 1920x1080 resolution, SuperClear MVA technology for wide-angle viewing, and 20M: 1 dynamic contrast ratio, this monitor provides incredibly sharp pictures and stunning video playback.
An integrated future-proof DisplayPort input, as well as DVI, VGA, and 2-port USB hub, offer easy and flexible connectivity options for viewing digital content sources, transferring files, and attaching peripherals. The LED backlight design makes this monitor Energy Star and EPEAT Silver certified. Standard 100 x 100mm VESA mount allows flexible wall mounting or display arm installation.
  • All-in-one video conferencing solution
    With Full HD resolution, an integrated webcam, dual speakers, and mic and headphone ports, this monitor delivers outstanding video and audio performance ideal for web and video conferencing.
  • Versatile connectivity
    DVI and VGA inputs give you the freedom to connect your monitor to a variety of devices.
  • SuperClear MVA panel technology
    Enjoy accurate and vivid colors with consistent levels of brightness no matter the vantage point. With SuperClear MVA panel technology, this monitor delivers the same image quality whether you are looking at the screen from above, below, the front, or the side.
  • Optimized view settings
    ViewSonic's unique ViewMode feature offers "Game," "Movie," "Web," "Text," and "Mono" presets. These presets enhance gamma curve, color temperature, contrast, and brightness to deliver an optimized viewing experience for different screen applications.
  • Dual integrated speakers
    Designed with dual integrated speakers, this display combines incredible screen performance with stereo sound for an immersive multimedia experience.
  • Enhanced viewing comfort
    With Flicker-Free technology and a Blue Light Filter, this monitor helps to eliminate eyestrain that comes with extended viewing periods - meaning you can outlast and outgame your opponents just as their eyes begin fail them.
ViewSonic Ergonomic VG2437SMC - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Camera, 2.0 megapixel camera, USB 2.0 hub
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Brightness
250 cd/m²
Contrast Ratio
3000:1 / 20000000:1 (dynamic)
Response Time
6.9 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA, DisplayPort
Speakers
Integrated
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
55.68 cm x 23.96 cm x 45.09 cm
5.2 kg
Environmental Standards
ENERGY STAR Qualified EPEAT Bronze
FCC Class B certified, UL, cUL, RoHS, WEEE
3-year warranty
Display Type
Diagonal Size
24"
Viewable Size
23.6"
Built-in Devices
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
Vertical Refresh Rate
50 - 75 Hz
Horizontal Refresh Rate
24 - 82 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
WLED
Controls & Adjustments
Brightness, contrast
SuperClearMVA, Eco-Mode, Flicker Free technology, Mercury free, Blue Light Filter technology
55.68 cm x 23.96 cm x 45.09 cm - with stand
5.2 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
2 Watt
Input
Camera
VGA , DVI-D , DisplayPort , 2 x USB 2.0 upstream , Audio line-in , Microphone , Headphones , Audio line-out
Mechanical
Tilt Angle
-3/+25
Swivel Angle
360
Rotation Angle
90
Height Adjustment
135 mm
VESA Mounting Interface
100 x 100 mm
Stand
1 x VGA cable , 1 x DVI cable , 1 x audio cable , 1 x USB cable , 1 x microphone cable
Security Slot Type
Kensington security slot
Power Supply
Internal
25 Watt
Included Software
ViewSonic Wizard
Microsoft Windows Vista / 7 / 8
Dimensions & Weight Details
With stand - width: 55.68 cm - depth: 23.96 cm - height: 45.09 cm - weight: 5.2 kg , Without stand - width: 55.68 cm - depth: 6.05 cm - height: 34.03 cm - weight: 3.7 kg
EPEAT Compliant
EPEAT Bronze
ENERGY STAR Certified
Limited warranty - parts and labour - 3 years , Limited warranty - backlight - 3 years
20 - 90% (non-condensing)
ViewSonic VG2437SMC 23.6 Bundle deal on ViewSonic VG2437SMC 23.6" VGA DVI DP USB LED Monitor with Integrated Webcam
£271.61
Diagonal Size: 24in
Interfaces: DVI
Interfaces: VGA (HD-15)
Brand: ViewSonic
Price Range Ex VAT: 150 - 300
