ViewSonic's VG2435Sm high-performance multimedia display features 1920 x 1200 resolution with 16:10 aspect ratio that provides a larger screen surface for increased office place productivity. With SuperClear wide-angle viewing technology, 50M: 1 dynamic contrast ratio and dual stereo speakers, it delivers sharp, consistent and true color performance together with crystal-clear sound effects. Fully ergonomic with flexible adjustment options, creating a more comfortable working environment is easy. In addition, it comes equipped with Flicker-free and Blue Light Filter technologies that reduce eye discomfort for daily users.
See more, work more with a 16:10 aspect ratio display
With an enlarged 16:10 aspect ratio and 1920x1200 resolution, this display enhances productivity by providing additional vertical screen space for viewing office docs, graphic design work, web browsing, and online media. -
Ergonomic design for comfort and productivity
With advanced ergonomic features, ViewSonic displays are designed to provide a greater range of adjustment for increased productivity and comfort. Users can reduce eyestrain and physical fatigue by adjusting the monitor via 360-degree swivel and more adjustment options. -
50M: 1 MEGA dynamic contrast ratio
Dynamic contrast ratio detects the brightness of an image, and automatically adjusts the backlight to maximize the monitor's color range and contrast. Dynamic contrast ratio technology enables the accurate reproduction of images, producing vibrant and rich visual effects. -
ViewSonic flicker-free viewing for improved eye comfort
ViewSonic flicker-free displays completely eliminate flickers and deliver on the promise of more comfortable viewing. This allows you to work at your computer, play games, or watch movies longer - without eye fatigue. -
Blue Light Filter for more comfortable viewing
Prolonged exposure to certain levels of blue light can cause eye discomfort. ViewSonic displays feature a Blue Light Filter setting that allows users to adjust the amount of blue light emitted from the screen, while maintaining a good color balance and reducing eye discomfort for work and multimedia applications. -
Dual integrated stereo speakers
The ViewSonic VG2435Sm has two integrated 2W stereo speakers for enhanced multimedia performance with crystal-clear stereo sound. -
Planet-friendly mercury-free LED backlighting
LED backlighting enhances display performance, delivers an outstanding color range, and adjusts contrast ratios for remarkably detailed images. ViewSonic's eco-friendly, mercury-free LED backlighting further conserves more energy. In addition, LED backlighting provides for a slim, lightweight profile that saves desktop space. -
SuperClear Image Enhancement technology with wide viewing angles
SuperClear Image Enhancement technology delivers the optimal color performance and extends display viewing angles to 178 degrees both horizontally and vertically. Experience accurate and vivid colors with consistent levels of brightness whether looking at the screen from above, below, the front, or the side - with no color distortion or decay.
- ViewSonic VG2435Sm - LED monitor - 24"
- LED-backlit LCD monitor - 24"
- Aspect Ratio
- 16:10
- Native Resolution
- 1920 x 1200
- Brightness
- 250 cd/m²
- Contrast Ratio
- 50000000:1 (dynamic)
- Response Time
- 5 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- DVI-D, VGA
- Speakers
- Integrated
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare, 3H Hard Coating
- Voltage
- AC 120/230 V (50/60 Hz)
- 55.68 cm x 20.43 cm x 39.36 cm
- 5.7 kg
- Environmental Standards
- ENERGY STAR Qualified
- GS, TUV Ergo, REACH, UkrSEPRO, ERP
- Display Type
- Diagonal Size
- 24"
- Aspect Ratio
- 16:10
- Native Resolution
- 1920 x 1200
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 5 ms
- Vertical Refresh Rate
- 50 - 75 Hz
- Horizontal Refresh Rate
- 30 - 80 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- WLED
- Controls & Adjustments
- Mute, volume, brightness, contrast, H/V position, sharpness, colour balance, input select, H-size, aspect control, blue reduction
- sRGB colour management, SuperClear, Eco-Mode, Flicker Free technology, blue light reduction, Mercury free, a-Si technology
- 55.68 cm x 20.43 cm x 39.36 cm - with stand
- 5.7 kg
Audio
- Speakers - stereo - integrated
- Output Power / Channel
- 2 Watt
- VGA , DVI-D , Audio line-in , Headphones
Mechanical
- Tilt Angle
- -5/+37
- Swivel Angle
- 360
- Rotation Angle
- 90
- Height Adjustment
- 100 mm
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x VGA cable , 1 x audio cable
- Backlight Life
- 30,000 hours
- Power Supply
- Internal
- Input Voltage
- Power Consumption (Typical)
- 31 Watt
- Included Software
- ViewSonic Wizard
- Dimensions & Weight Details
- Without stand - width: 55.68 cm - depth: 5.15 cm - height: 36.3 cm - weight: 4.1 kg , With stand - width: 55.68 cm - depth: 20.43 cm - height: 39.36 cm - weight: 5.7 kg
Sustainability Information
- ENERGY STAR Certified
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
