ViewSonic VG2435SM 24" 1920x1200 5ms DVI IPS Monitor
Quicklinx: 9YYGWS00 Mfr#: VG2435SM
ViewSonic's VG2435Sm high-performance multimedia display features 1920 x 1200 resolution with 16:10 aspect ratio that provides a larger screen surface for increased office place productivity. With SuperClear wide-angle viewing technology, 50M: 1 dynamic contrast ratio and dual stereo speakers, it delivers sharp, consistent and true color performance together with crystal-clear sound effects. Fully ergonomic with flexible adjustment options, creating a more comfortable working environment is easy. In addition, it comes equipped with Flicker-free and Blue Light Filter technologies that reduce eye discomfort for daily users.
  • See more, work more with a 16:10 aspect ratio display
    With an enlarged 16:10 aspect ratio and 1920x1200 resolution, this display enhances productivity by providing additional vertical screen space for viewing office docs, graphic design work, web browsing, and online media.
  • Ergonomic design for comfort and productivity
    With advanced ergonomic features, ViewSonic displays are designed to provide a greater range of adjustment for increased productivity and comfort. Users can reduce eyestrain and physical fatigue by adjusting the monitor via 360-degree swivel and more adjustment options.
  • 50M: 1 MEGA dynamic contrast ratio
    Dynamic contrast ratio detects the brightness of an image, and automatically adjusts the backlight to maximize the monitor's color range and contrast. Dynamic contrast ratio technology enables the accurate reproduction of images, producing vibrant and rich visual effects.
  • ViewSonic flicker-free viewing for improved eye comfort
    ViewSonic flicker-free displays completely eliminate flickers and deliver on the promise of more comfortable viewing. This allows you to work at your computer, play games, or watch movies longer - without eye fatigue.
  • Blue Light Filter for more comfortable viewing
    Prolonged exposure to certain levels of blue light can cause eye discomfort. ViewSonic displays feature a Blue Light Filter setting that allows users to adjust the amount of blue light emitted from the screen, while maintaining a good color balance and reducing eye discomfort for work and multimedia applications.
  • Dual integrated stereo speakers
    The ViewSonic VG2435Sm has two integrated 2W stereo speakers for enhanced multimedia performance with crystal-clear stereo sound.
  • Planet-friendly mercury-free LED backlighting
    LED backlighting enhances display performance, delivers an outstanding color range, and adjusts contrast ratios for remarkably detailed images. ViewSonic's eco-friendly, mercury-free LED backlighting further conserves more energy. In addition, LED backlighting provides for a slim, lightweight profile that saves desktop space.
  • SuperClear Image Enhancement technology with wide viewing angles
    SuperClear Image Enhancement technology delivers the optimal color performance and extends display viewing angles to 178 degrees both horizontally and vertically. Experience accurate and vivid colors with consistent levels of brightness whether looking at the screen from above, below, the front, or the side - with no color distortion or decay.
ViewSonic VG2435Sm - LED monitor - 24"
LED-backlit LCD monitor - 24"
Aspect Ratio
16:10
Native Resolution
1920 x 1200
Brightness
250 cd/m²
Contrast Ratio
50000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Speakers
Integrated
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
55.68 cm x 20.43 cm x 39.36 cm
5.7 kg
Environmental Standards
ENERGY STAR Qualified
GS, TUV Ergo, REACH, UkrSEPRO, ERP
Display Type
Diagonal Size
24"
Aspect Ratio
16:10
Native Resolution
1920 x 1200
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
50 - 75 Hz
Horizontal Refresh Rate
30 - 80 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
WLED
Controls & Adjustments
Mute, volume, brightness, contrast, H/V position, sharpness, colour balance, input select, H-size, aspect control, blue reduction
sRGB colour management, SuperClear, Eco-Mode, Flicker Free technology, blue light reduction, Mercury free, a-Si technology
55.68 cm x 20.43 cm x 39.36 cm - with stand
5.7 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
2 Watt
VGA , DVI-D , Audio line-in , Headphones
Mechanical
Tilt Angle
-5/+37
Swivel Angle
360
Rotation Angle
90
Height Adjustment
100 mm
VESA Mounting Interface
100 x 100 mm
1 x VGA cable , 1 x audio cable
Backlight Life
30,000 hours
Power Supply
Internal
Input Voltage
Power Consumption (Typical)
31 Watt
Included Software
ViewSonic Wizard
Dimensions & Weight Details
Without stand - width: 55.68 cm - depth: 5.15 cm - height: 36.3 cm - weight: 4.1 kg , With stand - width: 55.68 cm - depth: 20.43 cm - height: 39.36 cm - weight: 5.7 kg
Sustainability Information
ENERGY STAR Certified
10 - 90% (non-condensing)
