ViewSonic VG2239SMH 22" 1920x1080 5ms VGA HDMI DP USB LED Monitor
Quicklinx: BH0LWS00 Mfr#: VG2239SMH
Diagonal Size: 22in
Max Resolution: 1920 x 1080
Response Time: 5ms
Speakers: Speaker(s)
Interfaces: DisplayPort, HDMI, VGA (HD-15)
More than 50 in stock
£118.83 ex VAT
£142.59 inc VAT
The ViewSonic VG2239Smh is a Full HD LED multimedia monitor with future-proof connectivity and full ergonomic functionality ideal for corporate, government and education.
With SuperClear MVA panel technology for wide-angle viewing, and 20M: 1 dynamic contrast ratio, this monitor delivers incredibly sharp images and video playback. Integrated with HDMI, DisplayPort, VGA and 2 USB ports, the VG2239Smh allows flexible connection to PC systems, laptops and other multimedia peripheral devices.
ViewSonic's exclusive ViewMode provides intuitive presets to deliver optimized screen performance in different applications. In addition, Flicker-Free and Blue Light Filter technology help to eliminate eye strain from extended viewing periods. The LED backlight design makes this display ENERGY STAR and EPEAT gold certified.
  • SuperClear MVA Panel Technology with wide viewing angles
    SuperClear MVA panel technology delivers exceptional color performance and extends display viewing angles to 178 degrees both horizontally and vertically. Experience accurate and vivid colors with consistent levels of brightness whether looking at the screen from above, below, the front, or the side - with no color distortion or decay.
  • Versatile Connectivity with displayport
    The latest standard for rapid transmission of data, DisplayPort future-proofs this monitor and delivers the best refresh rate, highest resolution, and incredibly rich colors. This monitor also offers VGA connections, as well as an integrated 2-port USB hub, to support flexibility for both digital and analog media sources, as well as easy connectivity to peripherals and accessories.
  • The power of HDMI
    HDMI is a future-proof video standard that delivers true digital picture and audio clarity. The HDMI interface on this monitor allows you to connect to a variety of HD devices including gaming consoles, Blu-ray players, laptop PCs, digital cameras, and many others for the ultimate true high-definition experience.
  • Ergonomic Design for Comfort and Productivity
    With advanced ergonomic features, ViewSonic displays provide a greater range of adjustments including swivel, pivot, tilt, and height-adjust options.
  • ViewMode Settings for Enhanced On-screen Content
    With five intuitive scenario presets, ViewSonic's unique ViewMode feature offers best-in-class screen calibration for accurate color rendering and excellent performance. "Game," "Movie," "Web," "Text," and "Mono" presets enhance gamma curve, color temperature, contrast, and brightness to deliver an optimized viewing experience for different screen applications.
  • ViewSonic Flicker-Free Technology
    ViewSonic flicker-free monitors deliver a more comfortable viewing experience. Rather than using Pulse Width Modulation that continuously turns the LED backlight on and off, ViewSonic flicker-free monitors use DC modulation backlights that maintain a steady stream of direct current power - nearly eliminating screen flickering at all brightness levels by providing a constant LED light source.
  • Blue Light Filter for More Comfortable Viewing
    ViewSonic monitors feature a Blue Light Filter setting that allows users to adjust the amount of blue light emitted from the screen, enabling longer viewing times and increased eye comfort for work and multimedia applications.
  • Energy Star Certification
    Energy Star is a government-backed program that helps businesses and individuals save money and protect our climate through superior energy efficiency. By choosing Energy Star certified products such as monitors and displays, businesses can save up to 30% on energy costs while reducing greenhouse gases.
  • EPEAT Gold Certification
    EPEAT (Electronic Product Environmental Assessment Tool) is a definitive global rating system for greener electronics. This monitor has EPEAT Gold Certification, meaning that it meets 100% of EPEAT's 23 required performance criteria and a minimum of 75% of its 28 optional criteria.
  • Full HD 1080p for superior pixel performance
    This monitor features Full HD 1920 x 1080 resolution for unbelievable pixel-by-pixel image performance. You'll experience the most amazing clarity and detail whether it be while working, gaming, or enjoying the latest in multimedia entertainment.
  • Dual integrated stereo speakers
    This monitor is designed with two integrated 2W stereo speakers for enhanced multimedia performance with crystal-clear stereo sound.
  • Mercury-free LED backlighting
    LED backlighting not only enhances monitor performance, delivers an outstanding color range, and adjusts contrast ratios for remarkably detailed images, but it's also eco-friendly, mercury-free, and uses less energy than conventional monitors.
  • Eco-mode conserves more energy and cuts costs
    ViewSonic's proprietary Eco-mode energy-saving feature is built into all ViewSonic LED monitors. Eco-mode adjusts brightness and improves visibility, while reducing eye fatigue and prolonging the monitor's lamp life. With Eco-mode, the lifespan of the LED backlighting is also greatly increased.
  • VESA-mountable
    This monitor features a 100 x 100mm VESA-mountable design that allows you to mount the monitor depending on your specific needs.
ViewSonic Ergonomic VG2239SMH - LED monitor - Full HD (1080p) - 22"
LED-backlit LCD monitor - 22"
USB 2.0 hub
Panel Type
MVA
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Brightness
250 cd/m²
Contrast Ratio
3000:1 / 20000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA, DisplayPort
Speakers
Integrated
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
51.24 cm x 23.96 cm x 41.8 cm
4.8 kg
Environmental Standards
ENERGY STAR Qualified
FCC Class B certified, UL, cUL, WHQL, CB, RoHS, WEEE
3-year warranty
Display Type
Diagonal Size
22"
Viewable Size
21.5"
Built-in Devices
USB 2.0 hub
Panel Type
MVA
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
50 - 75 Hz
Horizontal Refresh Rate
24 - 82 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
WLED
Controls & Adjustments
Volume, brightness, contrast, input select
SuperClear, Eco-Mode, Blue Light Filter technology
51.24 cm x 23.96 cm x 41.8 cm - with stand
4.8 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
2 Watt
VGA , HDMI , DisplayPort , Audio line-in , Headphones , 2 x USB 2.0 , USB 2.0 upstream
Mechanical
Tilt Angle
-5/+20
Swivel Angle
360
Rotation Angle
90
Height Adjustment
135 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), Flicker-free technology
Stand
1 x VGA cable , 1 x DisplayPort cable , 1 x audio cable , 1 x USB cable
Backlight Life
30,000 hours
Security Slot Type
Kensington security slot
Power Supply
Internal
20.5 Watt
Included Software
Driver, ViewSonic Wizard
Dimensions & Weight Details
With stand - width: 51.24 cm - depth: 23.96 cm - height: 41.8 cm - weight: 4.8 kg , Without stand - width: 51.24 cm - depth: 5.64 cm - height: 30.44 cm - weight: 3.3 kg
ENERGY STAR Certified
ENERGY STAR Version
7.0
Limited warranty - parts and labour - 3 years , Limited warranty - backlight - 3 years
10 - 90% (non-condensing)
ViewSonic VG2239SMH 22 Bundle deal on ViewSonic VG2239SMH 22" 1920x1080 5ms VGA HDMI DP USB LED Monitor
£211.86
BH0L StarTech.com Articulating Monitor Arm In Stock £101.86
BH0L StarTech.com Dual Monitor Stand In Stock £69.36
BH0L StarTech.com Cubicle Monitor Hanger In Stock £45.29
BH0L StarTech.com TV/Monitor Arm - Wallmount In Stock £59.78
BH0L StarTech.com Monitor Arm - Heavy Duty In Stock £72.79
Diagonal Size: 22in
Response Time: 5ms
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: ViewSonic
Price Range Ex VAT: 100 - 150
