ViewSonic's VG2235m is a fully ergonomic 22'' multimedia display that features 1680 x 1050 resolution, 16:10 aspect ratio, and flexible adjustment options to provide a larger on-screen work area for greater productivity and comfort. Daily users will appreciate ViewSonic's Flicker-free and Blue Light Filter eye-care technologies that reduce eye fatigue caused by prolonged use. This ViewSonic LED display's the perfect choice for corporate, government, SMB and educational institutions.
See more, work more with a 16:10 aspect ratio display
With an enlarged 16:10 aspect ratio and 1680x1050 resolution, this display enhances productivity by providing additional vertical screen space for viewing office docs, graphic design work, web browsing, and online media. -
Ergonomic design for comfort and productivity
With advanced ergonomic features, ViewSonic displays are designed to provide a great range of adjustment for increased productivity and comfort. Users can reduce eyestrain and physical fatigue by adjusting the monitor via 360-degree swivel and other adjustment options. -
20M: 1 MEGA dynamic contrast ratio
Dynamic contrast ratio detects the brightness of an image, and automatically adjusts the backlight to maximize the monitor's color range and contrast. Dynamic contrast ratio technology enables the accurate reproduction of images, producing vibrant and rich visual effects. -
ViewSonic flicker-free viewing for improved eye comfort
ViewSonic flicker-free displays completely eliminate flickers and deliver on the promise of more comfortable viewing. This allows you to work at your computer, play games, or watch movies longer - without eye fatigue. -
Blue Light Filter for comfortable viewing
Prolonged exposure to certain levels of blue light can cause eye discomfort. ViewSonic displays feature a Blue Light Filter setting that allows users to adjust the amount of blue light emitted from the screen, while maintaining a good color balance and reducing eye discomfort for work and multimedia applications. -
Dual integrated stereo speakers
The ViewSonic VG2235m has two integrated stereo speakers for enhanced multimedia performance with crystal-clear stereo sound. -
Planet-friendly mercury-free LED backlighting
LED backlighting enhances display performance, delivers an outstanding color range, and adjusts contrast ratios for remarkably detailed images. ViewSonic's eco-friendly, mercury-free LED backlighting further conserves more energy. In addition, LED backlighting provides for a slim, lightweight profile that saves desktop space.
- ViewSonic VG2235m - LED monitor - 22"
- LED-backlit LCD monitor - 22"
- Native Resolution
- 1680 x 1050
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 20000000:1 (dynamic)
- Response Time
- 5 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- DVI-D, VGA
- Speakers
- Integrated
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare, 3H Hard Coating
- Voltage
- AC 120/230 V (50/60 Hz)
- 51.24 cm x 20.43 cm x 38.9 cm
- 4.85 kg
- GS, TUV Ergo, DOC, REACH, UkrSEPRO, ERP
- 3-year warranty (Austria, Germany, Switzerland - 3 years)
- Display Type
- Diagonal Size
- 22"
- Native Resolution
- 1680 x 1050
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 5 ms
- Vertical Refresh Rate
- 50 - 75 Hz
- Horizontal Refresh Rate
- 30 - 80 kHz
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Screen Coating
- Backlight Technology
- WLED
- sRGB colour management, Eco-Mode, Flicker Free technology, blue light reduction, Mercury free, a-Si technology
- 51.24 cm x 20.43 cm x 38.9 cm - with stand
- 4.85 kg
Audio
- Speakers - stereo - integrated
- Output Power / Channel
- 2 Watt
- VGA , DVI-D , Audio line-in
Mechanical
- Tilt Angle
- -5/+37
- Swivel Angle
- 360
- Rotation Angle
- 90
- Height Adjustment
- 100 mm
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), wall mountable
- Cables Included
- 1 x VGA cable , 1 x audio cable
- Backlight Life
- 30,000 hours
- Power Supply
- Internal
- Input Voltage
- Power Consumption (Typical)
- 18.5 Watt
- Included Software
- ViewSonic Wizard
- Dimensions & Weight Details
- Without stand - width: 51.24 cm - depth: 4.77 cm - height: 33.53 cm - weight: 3.25 kg , With stand - width: 51.24 cm - depth: 20.43 cm - height: 38.9 cm - weight: 4.85 kg
- Limited warranty - 3 years
- Regional Warranty Exceptions
- Austria, Germany, Switzerland - 3 years
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
