ViewSonic VG2233-LED 21.5" 1920x1080 5ms LCD Monitor
Quicklinx: 8SLWWS00 Mfr#: VG2233-LED
Diagonal Size: 21.5in
Max Resolution: 1920 x 1080
Response Time: 5ms
Speakers: [N/A]
Interfaces: DVI, VGA (HD-15)
11 in stock
£85.57 ex VAT
£102.68 inc VAT
The ViewSonic VG2233-LED is a 21.5" display ideal for demanding business professionals. With a native 1920 x 1080 resolution, the VG2233-LED delivers vibrant images and crisp text. Users will also find comfort in the fully ergonomic height adjust, swivel, and tilt features. Equipped with a VESA-mountable design, the display can be mounted on a wall or any VESA-compliant monitor stand. The VG2233-LED also saves up to 50% in energy usage with its efficient LED backlight.
  • Ergonomic design for comfortable working environments
    Users can reduce eyestrain and physical fatigue by adjusting the monitor to create their own most comfortable work environment. The VG2233-LED is designed to maximize comfort and productivity with advanced ergonomic technology.
  • Full HD resolution for superb pixel performance
    Experience the most amazing clarity and detail for any of your computer applications, Microsoft Office Suite operations, or for enjoying the latest multimedia entertainment. The VG2233-LED features Full HD 1920 x 1080 resolution to ensure excellent pixel-by-pixel image performance. Additionally, this 16:9 large screen allows the user to operate multiple windows side by side, thus facilitating a more efficient work environment.
  • MEGA dynamic contrast ratio delivers sharp and crisp images
    The superior dynamic contrast ratio of 20,000,000:1 delivers a broader range of grayscale, with darker blacks and brighter whites, to ensure all images displayed are rich and detailed. An extremely fast 5ms response time results in crisp and clear video performance. Experience digital broadcast-quality, full-motion video with razor-sharp images that never blur.
  • Eco mode saves energy and lowers total cost of ownership
    ViewSonic's proprietary eco mode function is built into all LED displays to provide setting options to "optimize" (75%) and "conserve" (50%). Both modes reduce display brightness and conserve up to 40% more energy. Eco Mode adjusts brightness and improves visibility, especially in low ambient light, to reduce eye fatigue and prolong display lamp lifetime. With eco mode, replacement expenditures are reduced while practicing eco-friendliness.
  • sRGB delivers the most accurate color performance
    Accurate and consistent color performance is essential for professionals in graphic design, video editing, and other multimedia related environments. With built-in sRGB color correction technology, the VG2233-LED reproduces images in their original and authentic colors.
ViewSonic VG2233-LED - LED monitor - 21.5"
LED-backlit LCD monitor - 21.5"
Aspect Ratio
Widescreen - 16:9
Native Resolution
FullHD 1920 x 1080
Brightness
250 cd/m2
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
5 ms
Input Connectors
DVI-D, VGA
Display Position Adjustments
Height adjustable, pivot (rotation), swivel, tilt
Screen Coating
Anti-glare, 3H Hard Coating
50.56 cm x 20.43 cm x 36.1 cm - with stand
4.68 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified , EPEAT Silver
3 years warranty
Display Type
Diagonal Size
21.5"
Viewable Size
21.5"
Aspect Ratio
Widescreen - 16:9
Native Resolution
FullHD 1920 x 1080
Brightness
250 cd/m2
Contrast Ratio
Response Time
5 ms
Vertical Refresh Rate
50 - 75 Hz
Horizontal Refresh Rate
24 - 82 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Screen Coating
Backlight Technology
WLED
sRGB colour management, Eco-Mode, Mega Dynamic Contrast Ratio
4.68 kg
VGA , DVI-D
Mechanical
Tilt Angle
-5/+25
Swivel Angle
340
Rotation Angle
90
Height Adjustment
100 mm
Flat Panel Mount Interface
100 x 100 mm
1 x VGA cable
Backlight Life
30,000 hours
Power Supply
Internal
AC 120/230 V ( 50/60 Hz )
22 Watt
Included Software
ViewSonic Wizard
Dimensions & Weight Details
With stand - width: 50.56 cm - depth: 20.43 cm - height: 36.1 cm - weight: 4.68 kg , Without stand - width: 50.56 cm - depth: 5.1 cm - height: 31.16 cm - weight: 3.09 kg
EPEAT Compliant
EPEAT Silver
3 years warranty
Service & Support Details
Limited warranty - 3 years
10 - 90% (non-condensing)
ViewSonic VG2233-LED 21.5 Bundle deal on ViewSonic VG2233-LED 21.5" 1920x1080 5ms LCD Monitor
£184.74
Response Time: 5ms
Speakers: [N/A]
Interfaces: DVI
Interfaces: VGA (HD-15)
Brand: ViewSonic
Price Range Ex VAT: 50 - 100
