The ViewSonic VG2039m-LED is a 20" (19.5" viewable) widescreen display ideal for demanding business professionals. With a native 1600 x 900 resolution, the VG2039m-LED delivers vibrant images and crisp text. Users will also find comfort in the fully ergonomic height adjust, swivel, and tilt features. Versatile input options, including DisplayPort, DVI-D, and VGA, provide flexible connectivity for multitasking. Equipped with a VESA-mountable design, the display can be mounted on a wall or any VESA-compliant monitor stand. The thin bezel design, coupled with hidden stereo speakers, makes the VG2039m-LED a space-saving option for the desktop. In addition to saving space, the VG2039m-LED also saves up to 50% in energy usage with its efficient LED backlight.
DisplayPort connectivity
The standard for rapid transmission of data, DisplayPort future proofs the VG2039m-LED and delivers high resolution and incredibly rich colors. The VG2039m-LED also offers VGA and DVI connections to support even more flexibility for both digital and analog media sources. It's easy and convenient to connect additional peripherals or accessories with the integrated 2-port USB hub. -
Superlative pixel performance
The VG2039m-LED features a native 1600 x 900 resolution for unbelievable pixel-by-pixel image performance. The VG2039m-LED provides 37% more pixels, as well as a 10% larger viewing area, when compared to 18.5" displays. You'll experience the most amazing clarity and detail whether it be for working, or enjoying the latest in multimedia entertainment. A 16:9 widescreen ratio minimizes eye fatigue, and is perfectly compatible with multi-window viewing without toggling. -
Efficiency and comfort
The VG2039m-LED is one of the great examples of an ergonomically designed tool. Based on your height, chair and desk conditions, you can adjust it up and down for 5.3-inch, swivel it 360°, or tilt it 20°, whatever makes you more comfortable. -
Planet-friendly mercury-free LED backlighting
The LED backlight conserves up to 50% more energy when compared to conventional CCFL displays. LED backlighting also allows for a sleek and slim panel profile.
- ViewSonic VG2039M-LED - LED monitor - 20"
- LED-backlit LCD monitor - 20"
- Energy Class
- Class A+
- Energy Consumption per Year
- 21 kWh
- Power Consumption (On mode)
- 14 W
- Aspect Ratio
- Widescreen - 16:9
- Native Resolution
- 1600 x 900 at 60 Hz
- Brightness
- 250 cd/m2
- Contrast Ratio
- 1000:1 / 20000000:1 (dynamic)
- Response Time
- 5 ms
- Input Connectors
- DVI-D, VGA, DisplayPort
- Speakers
- Integrated
- Height adjustable, swivel, tilt
- Screen Coating
- Anti-glare, 3H Hard Coating
- Black
- 46.6 cm x 25 cm x 38.2 cm - with stand
- 3.7 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified
- FCC Class B certified, UL, cUL, RoHS, REACH, TUV Nord
- 3 years warranty
- Display Type
- Energy Class
- Class A+
- 21 kWh
- 14 W
- Diagonal Size
- 20"
- Viewable Size
- 19.5"
- Aspect Ratio
- Widescreen - 16:9
- Native Resolution
- Brightness
- 250 cd/m2
- Contrast Ratio
- Response Time
- 5 ms
- Vertical Refresh Rate
- 50 - 75 Hz
- Horizontal Refresh Rate
- 24 - 82 kHz
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Screen Coating
- Backlight Technology
- WLED
- Controls & Adjustments
- Volume, brightness, contrast, colour balance, input select
- Eco-Mode
- Black
- 3.7 kg
Audio
- Speakers - stereo - integrated
- Output Power / Channel
- 2 Watt
- VGA , DVI-D ( HDCP ) , DisplayPort , 2 x USB 2.0 downstream , USB 2.0 upstream , Audio line-in , Headphones
Mechanical
- Height, swivel, tilt
- Tilt Angle
- -5/+20
- Swivel Angle
- 360
- Height Adjustment
- 80 mm
- Flat Panel Mount Interface
- 100 x 100 mm
- Included Accessories
- Stand
- Cables Included
- 1 x audio cable , 1 x USB cable , 1 x DVI cable , 1 x VGA cable
- Backlight Life
- 30,000 hours
- Power Supply
- Internal
- Voltage Required
- AC 120/230 V ( 50/60 Hz )
- 17 Watt
- On / Off Switch
- No
- Included Software
- ViewSonic Wizard
- Dimensions & Weight Details
- With stand - width: 46.6 cm - depth: 25 cm - height: 38.2 cm - weight: 3.7 kg , Without stand - width: 46.6 cm - depth: 5.9 cm - height: 27.4 cm - weight: 2.6 kg
- 3 years warranty
- Service & Support Details
- Limited warranty - parts and labour - 3 years , Limited warranty - backlight - 3 years
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
