ViewSonic VG2039M-LED 20" 1600x900 5ms VGA DVI DisplayPort USB LED Monitor
Quicklinx: 9M05WS00 Mfr#: VG2039M-LED
The ViewSonic VG2039m-LED is a 20" (19.5" viewable) widescreen display ideal for demanding business professionals. With a native 1600 x 900 resolution, the VG2039m-LED delivers vibrant images and crisp text. Users will also find comfort in the fully ergonomic height adjust, swivel, and tilt features. Versatile input options, including DisplayPort, DVI-D, and VGA, provide flexible connectivity for multitasking. Equipped with a VESA-mountable design, the display can be mounted on a wall or any VESA-compliant monitor stand. The thin bezel design, coupled with hidden stereo speakers, makes the VG2039m-LED a space-saving option for the desktop. In addition to saving space, the VG2039m-LED also saves up to 50% in energy usage with its efficient LED backlight.
  • DisplayPort connectivity
    The standard for rapid transmission of data, DisplayPort future proofs the VG2039m-LED and delivers high resolution and incredibly rich colors. The VG2039m-LED also offers VGA and DVI connections to support even more flexibility for both digital and analog media sources. It's easy and convenient to connect additional peripherals or accessories with the integrated 2-port USB hub.
  • Superlative pixel performance
    The VG2039m-LED features a native 1600 x 900 resolution for unbelievable pixel-by-pixel image performance. The VG2039m-LED provides 37% more pixels, as well as a 10% larger viewing area, when compared to 18.5" displays. You'll experience the most amazing clarity and detail whether it be for working, or enjoying the latest in multimedia entertainment. A 16:9 widescreen ratio minimizes eye fatigue, and is perfectly compatible with multi-window viewing without toggling.
  • Efficiency and comfort
    The VG2039m-LED is one of the great examples of an ergonomically designed tool. Based on your height, chair and desk conditions, you can adjust it up and down for 5.3-inch, swivel it 360°, or tilt it 20°, whatever makes you more comfortable.
  • Planet-friendly mercury-free LED backlighting
    The LED backlight conserves up to 50% more energy when compared to conventional CCFL displays. LED backlighting also allows for a sleek and slim panel profile.
ViewSonic VG2039M-LED - LED monitor - 20"
LED-backlit LCD monitor - 20"
Energy Class
Class A+
Energy Consumption per Year
21 kWh
Power Consumption (On mode)
14 W
Aspect Ratio
Widescreen - 16:9
Native Resolution
1600 x 900 at 60 Hz
Brightness
250 cd/m2
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
5 ms
Input Connectors
DVI-D, VGA, DisplayPort
Speakers
Integrated
Display Position Adjustments
Height adjustable, swivel, tilt
Screen Coating
Anti-glare, 3H Hard Coating
46.6 cm x 25 cm x 38.2 cm - with stand
3.7 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
FCC Class B certified, UL, cUL, RoHS, REACH, TUV Nord
3 years warranty
Display Type
Energy Class
Class A+
21 kWh
14 W
Diagonal Size
20"
Viewable Size
19.5"
Aspect Ratio
Widescreen - 16:9
Native Resolution
1600 x 900 at 60 Hz
Brightness
250 cd/m2
Contrast Ratio
Response Time
5 ms
Vertical Refresh Rate
50 - 75 Hz
Horizontal Refresh Rate
24 - 82 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Screen Coating
Backlight Technology
WLED
Controls & Adjustments
Volume, brightness, contrast, colour balance, input select
Eco-Mode
3.7 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
2 Watt
VGA , DVI-D ( HDCP ) , DisplayPort , 2 x USB 2.0 downstream , USB 2.0 upstream , Audio line-in , Headphones
Mechanical
Height, swivel, tilt
Tilt Angle
-5/+20
Swivel Angle
360
Height Adjustment
80 mm
Flat Panel Mount Interface
100 x 100 mm
Stand
1 x audio cable , 1 x USB cable , 1 x DVI cable , 1 x VGA cable
Backlight Life
30,000 hours
Power Supply
Internal
AC 120/230 V ( 50/60 Hz )
17 Watt
On / Off Switch
No
Included Software
ViewSonic Wizard
Dimensions & Weight Details
With stand - width: 46.6 cm - depth: 25 cm - height: 38.2 cm - weight: 3.7 kg , Without stand - width: 46.6 cm - depth: 5.9 cm - height: 27.4 cm - weight: 2.6 kg
3 years warranty
Service & Support Details
Limited warranty - parts and labour - 3 years , Limited warranty - backlight - 3 years
10 - 90% (non-condensing)
